Question about GE 46GW 948 46" Rear Projection Television
The colors are out of alignment causing the screen to appear 3D.
There is no way to adjust the screen by the remote so I am at a loss.
    Champion:
  • 240 Answers
Yes you can try.
goto convergence setings
slect menue on your remote
goto Convergence option 4 under (screen)
if this mode is mising you have an open resitor 750k ohm location on main pcb board is R19722
your tv set is also an RCA tpk195, if this helps
ptk195.
you might want to have a TV repairman look at the red blue and green convergence amp's.
hope this helps you.
regards,
daniel.
Posted on Jan 12, 2009
How do you get it out of 3d what do I adjust, its not a 3d tv
This is an color projector alignment issue. Many projection TVs have a menu item in the video or picture setup that will produce a grid overlay on a black screen of Red, Green and Blue. You use the <, >, up & down buttons on the remote or the TV to move each color (one at a time) directly on top of each other and maintain straight up and down / left and right lines. Once you do this, the picture will be in focus and there will be no more colored "3D-like" ghosting. If you are unable to move the colors far enough, there may be an issue with certain integrated circuits inside the TV that can be challenging to remove and replace. More make and model number for your TV would be required however.
May 21, 2014 | Televison & Video
My screen looks like its 3D.
Your tv has a problem with the convergence, adjust it using the original remote go to the setting's menu then go to the convergence section. Adjust the convergence color red and blue the green color is your guide you cannot move this green color, then you should move the red and the blue in all direction left to right, up and down. If you cannot move the red and the blue far enough the convergence IC is defective it must be replace in order to align this convergence. Feel free to send feed back good day and best regards.
Aug 14, 2011 | RCA HD56W66 56" HDTV
Dark picture and loss of focus on hitachi 61sdx01b
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 28, 2011 | Hitachi 61SDX01B 61" Rear Projection...
My picture appears to be out of convergence but i cannot adjust it back. Looks like the green is off a couple of inches.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 28, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Blue is not aligned and when i do the magic focus it gets stuck on the blue and a 4 appears on the bottom right corner
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 26, 2011 | Hitachi 51F500 51" Rear Projection...
My hitachi rear projection tv has one of it's colors out of alignment almost like it's been bent because it causes the blue color to be out of alignment in a curved fashion across the screen the tv worked...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 02, 2011 | Hitachi 50FX20B 50" Rear Projection...
Picture appears to be 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jun 25, 2010 | Toshiba 43A10 43" Rear Projection...
The screen looks as if it is 3D. The colors are all offset.
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
May 31, 2010 | Sony KP-57WS500 57" Rear Projection...
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
168 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
