Question about Coleman Powermate Premium Plus 6250W Portable Generator
Runs great for 30 minutes then shut off - Coleman Powermate Premium Plus 6250W Portable Generator
A friend of mine had that problem. they disconnected the low oil sensor n solved the problem.
Posted on Feb 03, 2013
Mine keeps shutting off within minutes why
I believe I solved the problem. It has been running now without shutting off. Before it would run from 30 sec to 5 hrs then shut off. I found the contacts under the swing out unit that were very dirty and covered with lint. I was able to get a small used tooth brush in and clean off the 2 metal contacts (be careful not to bent the contacts) now its working great once again.
May 15, 2016 | Ionic Pro TURBO Air Purifier
Truck start up run great couple minutes then shut off let set few minutes then crank up run great 30 second shuts down like you cut key off let set few minutes crank right back run fine then dose same
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
May 31, 2015 | Cars & Trucks
Z425
try alternator
Jul 16, 2017 | Garden
Maytag Dryer Model med5630TQ0, run it for 30 minutes works great run a second time for 30 minutes it automatically shuts-off and than I have to wait until it cools off to use heat option
Try cleaning out the vent in the wall and also check the vent hose to ensure its not kinked. If good air flow coming out of vent on back of dryer while running you could have a bad motor. Have to be disassembled to check it professionally.
Sep 25, 2017 | Dryers
Steiner lawn mower
Might be Coil Breaking down under heat. Not sure best way to diagnose other the cross your fingers and buy a new coil. Sounds like you did everything you could do Fuel -wise.
Oct 02, 2012 | kawasaki Garden
Location of oil pressure switch for a 1999 Buick LeSabre
My car runs great but after running for more than 15 minutes idle it shuts off and want restart for at least 30 minutes. Also my oil pressure continues to show I don't have when in fact I put some in the car. Plese help!!!!!
Dec 19, 2010 | 1999 Buick LeSabre
1999 Saturn SL
Cat. converter probably pluged. Mine did same today. Mechanic who tow my car said likely cause. I can hear fuel pump running, recent change fuel filter will check fuel pressure. But I will try emissionwiz fit too.
Sep 01, 2008 | 1999 Saturn SL
Nextvision n5
check your sleep timer settings. they stay on no matter how much you turn your unit on and off.
Oct 29, 2006 | ViewSonic NextVision N5 (n5-2) Video...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
49 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
