How do you replace battery in ds7700
Battery is no longer charging
  • 619 Answers
SOURCE: Replacement DVD Player Battery
recommended web site by fixya : www.12vAdapters .com
Posted on Jan 11, 2008
SOURCE: battery
First, the battery is a Lenmar PBA50 found on ebay.
Second, place the amplifer onyour lap with the battery cover off and tap it on your leg, the battery should slide out the back.
Third. I have 2 of these amplifiers and both would not charge or play on battery. The problem is the metal spring contacts the make contact on the battery, they get out of shape and fail. I bent them around until I was able to make the work, but do not like that solution. Beside the left in of the battery is a small "pocket" if you will. I opened up the amplifier (BECAREFUL the handle come loose and there are nylon washers on each side total of 4 that will do what ever they can to escape.) With the amp opened I located the 2 wires going to the metal battery contacts and cut them off and removed the contacts. I then drilled a hole into the small "pocket" and routed the wires down thru the hole. I remove the battery and carefully soldered a wire on each battery contact. I then put a et of connectors on the wire end making sure I kept the polarities correct and plugged the into each other. I now have very good battry connection and all works well.
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: battery is not charged - Sony DCR-TRV 25E
I SUGGEST YOU THAT YOU SHOULD CONTACT SONY,AND ASK THEM TO CHECK UP YOUR CAMCORDER.I THINK THERE IS SOMETHING WRONG WITH THE CHARGE CIRCUIT.
Posted on Jul 20, 2009
TOLhamRadio
  • 509 Answers
SOURCE: Delphi SkyFi3 Battery WIll Not Hold Charge
You can buy a whole radio for as little as $30. I would even call XM and tell them you're going to cancel because your radio died, and they might sell you one if you guarantee to stay with them for a year?
Posted on Aug 24, 2009
vanherringto
  • 1738 Answers
SOURCE: the battery on my tomtom 720 no longer holds the charge
You can purchase a new battery on eBay for less than $20 including shipping:
Click here: http://bit.ly/bgoqZ0
Posted on Feb 07, 2010
Why the battery of my unit is not charging? and When do i know the rechargeable battery is to be replaced?Coy
You need to replace the battery when it no longer charges or when the battery won't hold a charge and dies quickly. the charging symbol will light, as the charger is working, but in your case, the battery is not accepting or holding the charge.
Is this a hand-held DVD player?
Oct 23, 2015 | Televison & Video
D1oo Nikon enel3 lithium Battery packs stopped working
Batteries don't live forever. When handling them correct they can survive 1000 charge and discharge cycles. When taking an average of 200 pictures per charge, the battery could survive the camera shutter.
Try to use a battery till it is almost empty. The camera will give a warning when you need to replace (or charge) the battery. When you want to go on a trip or need to make a series of foot's you should take only charged batteries. When you don't use a camera, for a longer period, don't leave the battery in the camera. It could start leaking and damage the camera. But when the battery was not used for a longer period, please charge it before using it again.
This could help you to keep your batteries in better condition and let them live longer.
Dec 06, 2012 | Nikon ENEL3 Lithium Ion Battery Pack
Mac laptop dies when I pull the magsafe charger out of the socket and says not charging
check your battery. you may need to replace the battery if it is no longer charger. if you got 10.5 or 10.6 osx and if u hover ur mouse of the battery/charger icon it should say replace battery if its dead or service if its no longer holding a charge.
Apr 28, 2011 | Apple MacBook Mac Notebook
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
New battery
A lower capacity battery (12v 8Ah) can/should preferrably be replaced by a better capacity (12v 12Ah), and usually more expensive, quality battery of the same voltage with higher amperage rating: it will in general take longer to charge but will also last longer in usage.
Please make sure that you fully charge and discharge your new battery pack a few times to 'condition' it.
Hope it helps and have fun!
Aug 01, 2010 | Peg Perego 12 Volt Rechargeable Battery
I think my battery is dead. Do I try to charge it
To charge battery, use a trickle charger at 2 amp. Batteries usually only last about 3 years, so if battery is at that age it probably needs replaced. (Replaced my battery with a lawn mower battery that matched the original battery size.) I would try to get a charge on the battery before replacing it. Replacing the battery could be expensive. Battery could also be low on zinc, water, or acid.
May 22, 2010 | 2004 Yamaha V Star Custom
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
Your battery is dead when it no longer will hold a charge. Replace your battery.
Jun 02, 2009 | HP Pavilion dv6000z Notebook
My son's nintendo ds has been charging for a day now, but it
The battery is probably completely drained. Rechargeable batteries have a certain lifetime in which they can be charged to. The charge limit for a Nintendo DS is approx. 500 charges. When you pass this limit the battery will no longer work. Your best option is to buy a replacement battery at http://www.nintendo.com/consumer/
After a year or more a rechargeable battery won't last as long as it did when it was new.
Apr 07, 2009 | Nintendo DS Console
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
My unit just shuts off and will not turn on again until I plug it in as if to recharge the battery. I checked the battery when I first turned it on and it said the battery was fully charged.
Hi there!
It probably does need a battery replacement.
Even though it may show fully charged, and even test as fully charged, it may no longer have the capacity to deliver it for any sustained period.
If you think of a comparison between a 12V car battery, and a 12V alarm battery. Both show full charge, and the same output voltage, the difference is the available plate area. This is reduced due to degredation, and will no longer provide the same output.
Hope this helps.
If you want to make the battery last longer, charge for the recommended time (as was the first charge), then run the battery right down before charging.
If this solves the issue, Please rate as Fixya! thanks.
Jun 20, 2008 | Magellan GPS
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
