Question about Samsung SlimFit TX-S3082WH 30" TV
How do I select the correct input when using Direct TV
Do not know how to set up
    Top Expert:
  • Samsung Master
  • 14,553 Answers
See what the output is from the Direct TV box---if from the rear jacks it goes to the matching ones on the set. Coax to coax or more commonly component to component---rather straightforward.
Posted on Dec 04, 2012
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
How do u put tv on hd input
If this model has that it will be one of the rear sets of component jacks which will be marked as HD or 1080-----use the input button on the remote or the set if there to change to the correct input on the set. Hookup and select correct input.
Dec 03, 2012 | JVC AV-32S575 32" TV
Onkyo TX-SR805 Amp isnt projecting the picture through my Sony kdl46xbr. i am recieving sound but no picture. Reconnecting direct from source to TV and no issue so the problem is with the amp. HDMI symbol...
I have a 607 by Onkyo and you have to assign imputs to the imput selector. I don't know if your model uses the same, but if it does press setup and select input assign then select HDMI imput to see what it is set to.
Mar 06, 2011 | Onkyo Audio Players & Recorders
My TV signal source is a cable/satellite digital box. The setup screen correctly takes me as far as "Select correct input source for set top box." At this point - instead of leaving the...
I would suggest using dedicated input button on remote, not the menu on the tv. If you can skip setup screen that would be best. I have just looked at the manual for that tv, it tells you all you need to know, depending upon which input you used for your box. As I stated use the direct input button on the remote if you have it.
Oct 12, 2017 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
TRYING TO INPUT LAPTOP TO RGB IN,AUDIO WORKS BUT VISUALY "NO SIGNAL"
Reading the online manual - You should have the laptop connected by VGA - PC input
VGA Connection you need to select the correct input on the TV
  • Select the RGB-PC input source on the TV using the INPUT button on the remote control.
you will need to set the laptop up to output to the VGA output, to do this - varies by different manufacturers - But often F4 or F5, with the FN key selects the VGA output - have a look at the F keys across the top of the machine and see if you can see a picture of a screen - then use the FN and that F key together to toggle between display it will change to <Laptop Screen Only><Laptop screen and VGA output><VGA output only> not necessarily in that order.
This is the support site for that TV http://www.lg.com/us/support/product/support-product.jsp
direct link to the PDF user manual http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=37LG30&matchedModelCode=1000003995&searchEngineModelCode=37LG30&initialTab=documents&targetPage=support-product-profile#
Mar 31, 2010 | LG 37LG30 37 in. LCD HDTV
We have DirecTV and is is on channel 4. My
Use the tv remote to put the tv on ch 4. Use the direct tv then to select channel of the direct tv box. The box is broadcasting to the tv on ch 4. Also check that tv is on correct input . Again use the Panasonic remote to select correct input. If this does not work call direct tv for assistance.
Dec 03, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Want to hook up DVD player with red, white, yellow cable and need instructions to do so. Also, how do I view the movies on the screen. We seem to be having qa problem getting the correct connection and...
The Red & White Cable must be plug into the Audio IN of the TV RCA jack this is for Left & Right audio. The Yellow must be plug in into Video Input of the TV for the picture. If you select the AV1 as your DVD input, to view it you must set the tv to AV1.
Jul 20, 2009 | RCA F35673MB 35" TV
Connecting sony bravia to direct tv
select the correct scart socket used go though the av channels until you find the correct input[scart]
Apr 30, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Component video signal between KLH DVD8350 & Vizio 32" PlasmaHDTV
If the Visio TV has more than one input, don't forget to use its remote to make sure the correct input is selected. It probably wouldn't hurt to put a DVD into the player, confirm its running from the front panel counters) and let it keep running as you troubleshoot. At least then you'll know there is an active video source once you find it. Another thing you can try is to put in a music CD, if the player accepts these too (most do). Then when you get the TV set to the right input, at least you'll hear music, and can then go back to trying a DVD.
I know you're using component video, so remember that unlike HDMI devices, the TV is unable to switch to the correct source automatically. So it may just be that you've never had to switch the TV's input source before. Good luck! :-)
Jun 02, 2017 | KLH DVD8350 DVD Player
Samsung SlimFit  TX-S3082WH 30" TV Logo
32 people viewed this question
Jerry Greenberg
Jerry Greenberg
