Question about Bosch Axxis+ WFR 2460 Front Load Washer
Bosch wfk2801 washing machine drum does not rotate
The machine goes through its cycle but the drum does not rotate. The spin function therefore does not operate.
This problem has occurred since we had a blockage in the outlet pipe which ahs now been cleared; is thie purely a coincidence?
Thanks
  • graham173 Jan 15, 2009
    Excellent advice given swiftly and accurately many thanks :)
  • Anonymous Feb 04, 2009
    bosch maxx7
  • Bosch Master
  • 3,463 Answers
Remove rear panel and check the belt is o/k, if it is, then remove belt, undo 2 bolts that hold motor, unplug the motor connector, lever motor back with a screwdriver, and remove motor.
Check the brushes, they should be at least 5mm long, \any shorter, then replace.
Plz rate my solution.
TRhanks.
Posted on Jan 11, 2009
The drum on my WFL2461 is not spinning(centrifuging)
This is not something that is easy to fix. The front load machines use a DC motor. If the drum works when it washes and it does not spin, the issue could be the motor controller.
Oct 10, 2012 | Bosch Axxis WFL 2060 Front Load Washer
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
Washing machine won't spin or rotate
Sounds like the motor brushes need replacing, you will have to remove the motor to do this.
Hope this helps.
Please leave feedback.
Nov 29, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Drum will not rotate or spin
oooops - the motor was stuck under the carriage. Once
moved it came off easily.
Jun 17, 2008 | Bosch WFK 2401
Bosch Axxis+ WFR 2460 Front Load Washer Logo
1,151 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
