Question about Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth Pandora Link,iPod Support &
What do you hook the orange wires to on a wiring harness for a pioneer car radio
Hooked up wiring harness and radio will not come on when you turn the car on.
zzedly
  • 300 Answers
SOURCE: pioneer prsx720 wiring question
If the subs are dual 4 ohm voice coils, you could hook the DVC's of each sub in parallel ("+"'s together, "-"'s together) making each sub essentially 2 ohms. Then connect one sub to each channel of the amps. This will put about 200W on each sub.
Posted on Mar 14, 2008
  • 631 Answers
SOURCE: Pioneer GM-5100T Car Audio Amplifier IS THE SYSTEM CONTROL WIRE THE SAME AS REMOTE WIRE
System control is the same as the remote turn-on from the head unit.
Posted on Nov 05, 2008
SOURCE: I have a pioneer car radio amp that will not turn
if not the ground connection check fuse in power wire from batt
Posted on Mar 23, 2009
  • 4 Answers
SOURCE: Red light showing up on amp ( pioneer 800 watt GM 7200 amp )
it could be the amp it could be the way you've installed and if you have a sub in an enclosure the wires could be touching the postive and negetive speaker wires what ever the problem is the amp is in protection mode i hope this helps hope its not the amp i hope its just the wiring
Posted on Jun 05, 2009
  • 12 Answers
SOURCE: I have a Pioneer GM H22 amp. Powers up nice, fan
On Pioneer, Green wires are left spkrs, Grey is right spkrs solid is positive black stripe is neg.
Posted on Jul 07, 2009
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
Im trying to install an after market radio(pioneer) in my 83 impala. i know i hooked up speakers correctly. But i have a yellow black and grey wire on car wires and yellow black and red on harness. I know...
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Here you go. This is listed for an 85 to 89 Impala, but should still hold true.
May 30, 2011 | Pioneer Car Audio & Video
I have a 1996 Dodge Intrepid. I just installed a radio in the car using the Wal-Mart wiring harness, but when I turn on the radio, I have to turn it all the way up to hear the music, and its all treble....
that aftermarket radio may require different ohm speakers than whats in the car. open trunk and look at speaker magnets they will have the ohms printed on them if they dont say 4 or 8 ohms then they are incompatable with your stereo and may damage it if ohms are lower than 4 ohms. also make sure your radio balnce tone fader settings are correct. some of these new radios are so comlicated with that stuff it requires a 100 page book just to operate it.
Apr 28, 2010 | 1997 Dodge Intrepid
Pioneer Avic D3 has poor fm reception when the car is on. It works fine when the car is off. Any ideas?
Your power antenna wire maybe hooked up to ignition. So when you turn off the car no more voltage is going to your antenna wire so your power antenna goes down causing a poor reception. You must hook up the blue wire on the radio harness to the power antenna wire.
Apr 10, 2010 | Pioneer AVIC-D3 Car DVD Player
My pioneer deh-p5500mp Car Radio
hmm.. thats a nice radio, not too shaby heheh...
Well your car radio should have a Blue wire with a white stripe for the remote, in case you are interested in the user manual (wich im guessing you dont have)
Go to:
http://www.nodevice.com/user_manual/pioneer/car_audio/deh-p5500mp.html
it has a diagram of the harness and it shows a blue/white remote wire, so im guessing that you bought it used and probably got a different harness with your car radio... but then again thats too weird
you could do a check to see if thats really the problem... just feed 12V From the power terminal of your amp to the remote terminal, that should turn your amp on and you should be able to listen to your car radio's output (id suggest not setting the volume all the way up when doing this XD)
Hope it helps
Jun 23, 2009 | Pioneer DEH-P5500MP CD Player
Stereo turns off when headlights turned on
Sounds like you have the ground for the radio hooked up to the illumination ground wire. Check for orange or orange/black wire coming from the radio harness. Did you buy the harness for the car as well? If so then just match all the colors of wires from the car harness and the radio harness. By car harness I mean the harness that plugs into the harness that the original factory radio plugged in to.
Thanks
Mar 29, 2009 | Car Audio & Video
Kenwood kdc-415s
if there is no amplifier separate from the radio - the blue /white wire from the back of the radio goes to the solid blue wire on the harness attached to the car's plug. the orange wire is not supported by the kenwood radio, so make sure you tape it well- if your not using a separate amp also tape up the blue/white wire coming off the harness you have coming out of the harness to the car. if this helps you please give me a good rating- if not please e-mail me at Merle840@aol.com respectfully M. Merle
Oct 13, 2008 | Kenwood KDC-415S CD Player
My pioneer deh-1900 mp will not turn on
did you use a wire harness adapter or did you connect the wires from the radio directly to the wires in the car? do you have a computer safe test light or a digital vom meter? do not use a conventional test light in this car or an analogue meter to check for power
Feb 09, 2008 | Pioneer DEH-1900MP CD Player
Pioneer DEH-X6500BT MP3/USB A2DP Bluetooth Pandora Link,iPod Support & Logo
108 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
