The sound stopped working on my tv i tried unpluggin it and waiting awhile then pluggin it back in. unfortunately i didn twork. if anyone could help it would be very much appreciated.
the fan is old and, is off balance (noisy) it can't keep your tv cool so the tv shuts off
open the tv and, remove the fan. replace it with one off e-bay
This may help with yours since it was built in 99
Product Safety Information
Product Safety information is contained in the appropriate TCE Service
Data covering models/chassis referenced herein. All specified
Product Safety requirements and testing shall be complied with prior to
returning equipment to the customer. Servicers who defeat safety
features or fail to perform safety checks may be liable for any
resulting damages and may expose themselves and others to possible injury.
First Edition ¾ First Printing
Copyright 2000 ¾ Thomson Consumer Electronics, Inc.
Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s)
Symptom: Shutdown during channel change, shutdown during autoprogram,
dead set or unexplained
random shutdown.
Cause: Incorrect F2PIP Power on Reset (POR) timing
Cure:
Product Support · Mail Stop INH 900
P.O. Box 1976 · Indianapolis, IN 46206 -1976
TV 00-003
Television
TTI TV 00-003
MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP
DATE: July 14, 2000
TOPIC: F2PIP
The following modifications are required to change FPIP POR timing for added
reliability.
NOTE: All chassis manufactured after 950XXXXXX have the modification
installed.
Follow these steps in order.
All CTC195/7 – All CTC203
1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground
(192096). Note: This may require “piggybacking” the resistor on top of
C18114.
MM101 Chassis
C18119.
The next steps are dependent upon the chassis under repair.
CTC195F, F2, F3 chassis
2. Replace R18111 with a 100K resistor (192084)
3. Replace C18118 with a 330nf cap (220132)
4. This concludes the modifications for these chassis.
CTC195/7 (except CTC195F,F2,F3) and all CTC203
2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of
U18100
3. Replace C18121 with a 330 nanofarad cap (220132)
4. This concludes modifications for these chassis.
MM101 Chassis
No further modifications are necessary.
What kind of computer do you have? There wuold have to be a video out or SVHS plug out from your computer. And a video or SVHS input to your TV. If both are physically available then there should be a computer configuration so your laptop can output to your TV.
the front panel assembly is rca part # 237420
I assume your chassis is a CTC203
Un plug the fpa and see if problem still acts up
you may not be able to find one
then try replacing the sticking buttons on it
