No audio from tv, speakers not detected. - Audio Players & Recorders
    Sergeant:
  • 256 Answers
Go into the setup menu, The speakers might be turned off,
Posted on Dec 04, 2012
Do I need to turn off the tv speakers to get tv sound from my soundbar?
How to Connect Soundbar to TV audio
I would think that the tv would automatically detect a cable being plugged in. It should only send sound to the soundbar once it is connected. Make sure the soundbar is on when you do your testing. You may have to change the audio settings on your tv in order to send audio to the soundbar.
Sep 07, 2016 | Televison & Video
How do I connect ILive ITO82B Sound Bar to an LG TV?
This will depend on what inputs your sound bar has and what outputs your LG TV has, typically LG have Optical DIgital Audio (Sony TOSLINK), Headphone (Analog stereo), And HDMI reverse audio from HDMI 1 only. On some LG TV's you have to turn the external sound on, and on others it is auto detected, also make sure the TV speakers are off, or you can get weird phasing from 2 outputs (TV + Soundbar).
Jan 04, 2015 | LG Televison & Video
Rear speakers no sound using coax cable from TV/Blue Ray player. In the setup test the rear speakers worked perfectly
You may have to manually select a surround mode. The receiver might not be detecting the signal correctly.
Jun 20, 2013 | Pioneer Audio Players & Recorders
When i plug in the speakers no sound is coming out it doesn't work correctly i cant hear anything i'm playing.
Hi taceeg06,
Have you check all the Volume setting on you computer?
On the lower right side look for the computer Icon check if there is a red X on the speaker Icon, if there is then it can be that here is something wrong with the speaker driver or it does not detect the speakers.
If you do not see the speaker Icon then the Driver for the Audio card is not installed on the computer and you may need to re install that Audio Card Driver to be able to regain the audio from your Speakers.
Also the speakers should connect to the Green Audio Jack behind the computer, if it is then still no Audio you can try the Audio Jack in front of the computer as well to check the Audio Card in the Machine, if the front and back audio jacks do not detect nor produce sound when the speakers are connected then re installing the driver for the Audio card may work, unless during the installation an error shows that the there is no audio device detected then it means the Audio Card is busted.
Let us hope not since it is very seldom an Audio Card could go busted.
I hope this helps.
Have nice day,
mvincentc
Jun 12, 2011 | Insignia 2.0 Speaker System (2-Piece)
I cant get any sound I did the trouble shooting
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
Mar 07, 2011 | Mitsubishi LT-40151 40 in. HDTV LCD TV
I just sold my surround sound system and now I can't get the on board speakers to work.
Just check the rear of the television if by chance you have left any cable still connected to the audio output jack. If there the TV might be trying to redirect the audio to an external device not present. Sometimes it could also be a simple setting to be changed , . Check if you have a switch at the back of the TV stating External or Internal speakers. From the manual i got
A/V Receiver: The TV can detect audio connections on the DIGITAL AUDIO OUT jack and the right (red) analog AVR AUDIO OUTPUT jack.
Note for Analog A/V Receivers: When you disconnect an analog A/V receiver, manually change the Speakers setting to TV to hear sound from the TV speakers.
Press Menu on the remote-> Goto AV
Select Audio by pressing the right key
Under that the first option of Speakers -> select and set to TV.
Only then will the TV speakers play the audio.
Hope this Helps.
Mar 04, 2011 | Mitsubishi Televison & Video
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
Tv speakers are not picking up audio from tv
Try unplugging the unit for 15 or 20 minutes. Sometimes the microprocessor needs to be reset in these units. Thanks
Oct 28, 2009 | RCA P52926 52" Rear Projection Television
14 people viewed this question
 Grubhead
Grubhead
