Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Heats up but no steam - Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
I took the head off of mine and saw that there was plenty of steam coming out and found that the head was clogged. I inserted a wire in the head part to try and dislodge the clog. I used 1/4 distilled water and 3/4 of distilled white vinegar and pumped it continuously until the steam came out. I then took the head off again and inserted a wire to clean it more and repeated the process and it works great now.
Posted on Dec 06, 2012
Does this cleaner heat up the water for steam? It is called a steam cleaner, but I do not see anything about how to regulate the temperature of the water to make the steam and so no one gets burned.
Steam is steam is steam - it has a temperature of 212 degrees F and if you go any lower it is no longer steam - condenses back to water. Capiche? If you pressurize the steam you can then raise its temperature to a super heated condition. How do you think a pressure cooker works??????
Aug 26, 2017 | Vacuums
Steam will not travel through hose scunci steamer ss1000
Blocked with limescale maybe? if its heating to correct temperature to disperse steam then I has to be blocked, that or its not heating up to boiling heat
Mar 03, 2014 | Vacuums
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
My shark steam mop will heat up but not steam when i push the handle down. I have put CLR in it and let it sit over night. it still is not steaming up but it heats up. Tina
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Jul 05, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop heats up but stopped putting out steam.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Mar 08, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
The steam mop doesn't seem to be "steaming"...even though I leave it on long enough to heat up. I can hear the steam but it doesn't seem to heat the pad
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Feb 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Cleaner heats up but no steam is coming out. It let loose a big ball of steam when I plugged it in, then nothing and still won't heat up enough to produce steam.
heatman101
nt
Nov 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop model #S3202 is no longer heating and producing steam
The heating element may have died or there is an obstruction...
heatman101
Jul 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My mini steam zapper heats but produces no heat
you should get steam in the amount of time it take to boil water
Feb 18, 2009 | EuroSteam Vapor Steam Cleaner Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
102 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
