Srreen screen do not light up - Computers & Internet
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Dec 04, 2012
Having issues with screen, everything with computer works and lights are all turning on but screen wont light up and shows no image.
This sounds like a faulty hardware. i would suggest taking it to sony if its still under warranty and get it replaced. if not contact a local technician.
May 31, 2015 | Sony VAIO Duo 11 SVD11225CXB 11.6"...
If the touch screen wont light up on a falcon 4220 does that mean the touch screen itself is bad?
THE TOUCHSCREEN/DIGITIZER IS A DIFFERENT PART FROM THE ACTUAL SCREEN , YOU JUST HAVE A BAD SCREEN .DIGITIZER IS GOOD .
HOPE THIS HELPS ,IF NOT I CAN HELP YOU MORE
Nov 19, 2014 | Datalogic PSC Falcon 4220 Data collection...
Why does my Janome MC9000 screen not light up, it sews ok, needle works up and down.
It depends on the screen; a few have a small light or lights behind them, but I believe for most modern screens, the lighting is in the screen itself. It sounds as if yours is not working, but it CAN be replaced, and it's not a hard job to do so--although the part may be a little pricey. It's roughly equivalent to the screen of a laptop not working.
This is definitely a job for a technician.
Sep 13, 2014 | Sewing Machines
When my computer boots up sometimes the screen is ok, but more often the screen fades and goes black. If I switch the monitor off and then on again the screen shows the icons etc for about 2 seconds and...
This could be that the screen topback light or bottom back light is bad or the inverter.
the topback or bottom back light could also be seing as the flouricent of the screen that light up the screen to enable display visible.This top back light or botom back light as the name implies is positioned at the top and bottom side of the screen.It takes an expertize knowledge for one to be able to change the flouricent when comfirms bad.The same is applicable with Inverter.
Jan 06, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
My dish washer is not cleaning the dishes properly.it almost seems as if the top rack is no being clean.
try using dishwasher majic or a cleaner / ck the holes in wash arms as the must be clear . clean srreen in bottom and make sure the water tempt is hot enough .min 130 to 140 deg . low water tempt cause=s most dw washability problems . + a fresh dergt. podwer is best as liq freeze in winter and are no good. //**** .hope this helped .
Dec 23, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
Screen on laptop won't light up
There is a board called an inverter behind the screen besel. The inverter is like a balast in a flouresent light. The inverter supplies the power to light the screen.
Oct 20, 2009 | Toshiba Satellite Pro L300-EZ1005X...
I have a problem with my psp I can't see nothing in the screen but i can hear the sound of the psp
Hi
i have had a similar problem,
this could be one of two things
1 your screen back light is damaged
2 your LCD screen has been very badly cracked
dose your screen light up at all?
if it dose light up then you would need to replace the screen
if it doesn't light up you may just need a back light.
Aug 27, 2009 | Sony PlayStation Portable (PSP) Console
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
I BOUGHT A LC42D43U TV AT SAMS CLUB ON BLACK FRI AFTER CHRISTMAS....NOW THE LEFT SIDE OF THE SRREEN IN WHITE AND ONLY THE RIGHT HALF HAS A PICTURE...WHAT DO I NEED TO DO....THANK YOU CHUCK HAIMAN ...
The lc42d43u has a control board that supplies the picture to four quadrants of the lcd panel, it sounds like either half of that control board is bad or you have a bad panel. Sharp does not supply panels but will replace the control board, If the panel is bad they will usually replace the tv or make some other concession. since you bought it at christmas it should be under the 1 yr manufactures warranty. I would suggest calling sharp and finding your nearest authorized service center. Thanks, hope this helped.
Apr 02, 2008 | Televison & Video
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
