Question about ViewSonic VX2235wm LCD Monitor
Monitor will flash windowsxp when I boot up CPU but then goes out
The power light stays on even though there is no picture. It never stays on more than a second even if I turn the power on Monitor off then on again it will flash a picture then go black.
    Scholar:
  • 63 Answers
Your monitors backlight is shutting off due to a failed component. The inverter circuit which drives the high current CCFL backlights, has a feedback design so that if there are any problems with the devices along the high current path, the high current will shut off. This way if something got shorted out, it would not sustain or cause any great harm. This is a great feature if you are the "short" in the circuit.
So in actuallity, your monitor is still on, and it's still showing you a picture. You just can't really see it because the light from behind has turned off. If you take a flashlight and put it up close to the screen, you'll see your desktop again!
As to what is causing this, It can be several things.
-A broken or burnt out CCFL
-A bad capacitor in the power supply filter or on the inverter.
-A shorted out IC.
-A mouse has crawled inside your LCD and chewed the CCFL wires. (this usually is accompanied with a high pitched squeeling sound, and/or smoke)
You can send me the entire monitor and I will repair it for $40. You pay shipping costs BOTH ways. Let me know if you're interested and I'll provide you with more information on where to send it.
Thanks
Chris
Boise LCD
sales@boiselcd.com
(208) 891-9117
Posted on Apr 03, 2009
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 15, 2011 | HP Compaq WF1907 Monitor
I have a Toshiba Tecra-M2-S410 machine, and it does not turn on anymore. When I remove the battery and plug it in, the power light turns green as expected. When I press the power button, two other lights...
Hi mohammad - seems the LCD of the laptop is gone bad . as u said u gets the light on the laptop and also sound and then it goes dark - shows possibly the LCD gone bad .
Give a try with this if you have a computer in your home - on the back of the monitor you will find a VGA cable (probably with a blue color end which goes to cpu ) unplug it from cpu and plug it in the laptop (side of laptop you will find a same input VGA slot blue color ) and boot your laptop after turning on both (monitor and laptop) if you find the screen on the monitor then it will be sure that your laptop LCD has gone bad .
On your laptop if you are not able to find the boot screen also that refers to LCD brokerage -anyway try the above you will be sure ..
Oct 01, 2010 | Toshiba Tecra M2-S410 (032017233812) PC...
When pluged into outlet fans spins and doesnt stop, wont boot
Fan spinning hard is usually a CPU issue.
If you've made any hardware changes to your computer, undo them. This happened to me when I was trying to upgrade my Processor (CPU) and I had the wrong kind.
Mar 09, 2010 | HP Pavilion m7560n PC Desktop
Laptop powers on but will not boot. Keyboard lights remain on. Disk light comes on for a second and then goes out.
For all troubleshooting, have the notebook connected to the DC power supply.
Does the power stay on? if the power goes off are you getting any beep codes or do the leds flash in a specific pattern? if no beep/led codes, and system turns off, then it's likely to be a bad system board or cpu. if power stays on, but you see nothing on the display, the lcd could have gone bad. can you connect an external monitor to this unit?
Oct 03, 2009 | HP Pavilion ZV5260US (PF144UA#ABA) PC...
Monitor goes dead after after switch on after 3seconds
CCFL backlight may be busted.. also ccfl inverter may need repair or replacement too..
Mar 09, 2009 | GNR 19M1 19" LCD Monitor
Monitor goes to sleep and won't wake up
You can google search for an app called NOSLEEP.EXE
It was written by a Symantec employee to keep your screen active regardless of pic settings.
Install and run it. That will verify the issue is with of or monitor
Software is free
Apr 09, 2017 | Mag Innovision LT776s 17" LCD Monitor
Thinkpad T20 no boot
TRY TO GO OLD SCHOOL AND USE A WIN 98 SART DISK OR TRY TAPPING F8 ALOT DURING START UP AND SELECT STEP BY STEP START
Dec 19, 2007 | IBM ThinkPad T20 2647 Notebook
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
ViewSonic VX2235wm LCD Monitor Logo
483 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
