Question about SVP New PP003 Portable Multimedia Pocket Mini Projector Up to 54-
SVP WON'T READ ANY FORMAT FROM SD
NO MATTER WHAT FORMAT IN TRANSFERED TO AN SD AND THEN ATTEMPTED TO PLAY IN THE PROJECTOR IT SIMPLY WILL NOT PLAY ... IF THERE IS NO SOLUTION FOR THIS I AM RETURNING THE UNIT ... DOES ANYONE HAVE AN ANSWER FOR THIS ?
Tevion Dvd player won't read burned cd's or dvd's.
Transfer your .avi movie files onto a USB stick & simply plug them into the Tevion DVD player.
Select the usb button on the remote to activate & choose which film to play from the menu that pops up.
Mar 10, 2013 | Televison & Video
When i play a video on my phone that's not recorded, it won't play and the video's format is 3gp but it still won't work
Though 3gp works on mostly all mobile but their size also matters, if file is big or its a movie that you have converted then its unlikely as file size id big and unrecognizable in some models
Oct 10, 2012 | Nokia 6300 Cellular Phone
Memory card needs to be formatted for Dell Inspiron n4050
run the chkdsk utility on it
right click on your sd card select properties tools check now place a tick in both boxes to scan for and attempt to recover bad sectors and corrupt files
(I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Sep 17, 2012 | Computers & Internet
I have a vir-5850nr touchscreen and it won't read my sd card. It takes forever to load and then it just shows a
Hello there 1st thing u need to know about sd cards with this stereo is that u need to make sure that the sd card is not sdhc, the card has to say simply sd, check that 1st, more then likely thats ur issue, if any stereo says that it takes sd but not sdhc, then u simply need to get the appropiate card, they r 2 very different cards even though the size is the same
Apr 27, 2012 | Soundstream VIR-5850N Car Video Player
PNY optima sdhchd 8gb won't read in my Kodak easy
What model Kodak EasyShare camera? Some of them only work with SD cards, not with SDHC cards. The same applies to kiosks. Make sure the slot is marked "SDHC' and not simply "SD".
Feb 05, 2012 | SanDisk Cameras
My HTC inspire all of a sudden won't read any of
Try using another SD card to see if that one will read. If so, there is a problem with your SD card.
But if that card is also unable to be read, and your phone is fully updated, there is a problem with the reader on your HTC handset. You can contact HTC for a repair or a replacement. You might even have some luck at the retailer where you originally bought your phone. It's a fairly new model.
Here's HTC's number:
866-449-8358 6am-1am Eastern Time
Jun 15, 2011 | HTC Inspire 4G Smartphone
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Feb 28, 2011 | Casio Lighted Keyboard LK90STADMC
Cant format sd card
Having received no response to my query in over a month, I assume it was simply a matter of attempting to use an SDHC card in an SD device.
Aug 22, 2010 | Kodak EasyShare CX7430 Digital Camera
Can't format sdhc card in my camera.
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Mar 04, 2009 | SVP CDC-8610 Digital Camera
Camera says this card cannot be used on power up.
either the card is not supported or it needs formatting
Nov 25, 2008 | Nikon COOLPIX L5 Digital Camera
SVP New PP003 Portable Multimedia Pocket Mini Projector Up to 54- Logo
18 people viewed this question
Top SVP Computers & Internet Experts
David Payne
David Payne
Are you a SVP Computer and Internet Expert? Answer questions, earn points and help others
