Question about 3M Littmann Cardiology S.t.c 27" Stethoscope - Available In All Colors
I need to change stethoscope tubing
Does anyone know how to change the tubing on a Littmann STC?
3 Suggested Answers
crazydani
  • 17 Answers
SOURCE: Hi, i have a Littmann
How does the seal look on the chest piece part? A lot of times it can be cracked which would cause your problems.
Posted on Jan 30, 2011
SOURCE: can't turn diaphragm to bell - seems stuck?
hello i had the same problem the solution remove the plastic Tunable Diaphragm and Rim and remove Diaphragm from the tube then pour some oil in the bell and let for some time and then try moving it it worked with me from the first try then clean the metals from any oil before putting everything back
Posted on Aug 14, 2013
Is a littmann classic ll S.E diaphragm rotate 360 degree
sorry , no it does not it should only rotate 180 degrees this allows you to change from the bell to the diaphragm. send it back to the factory, call them they may even send you a new one.
Mar 10, 2014 | Littmann Stethoscopes Littmann Classic II...
The diagram cover came off of my stethoscope. I can not get it to go back on and I need to use this stethoscope. I have only used a few times.
Normally, the retaining ring on the head of the stethoscope screws on and off, so the diaphragm can be cleaned or replaced, as necessary. Have you tried that?
Feb 18, 2011 | 3M Littmann Lightweight Ii Se Stethoscope
Help!!! my litmann 4000 wont turn on even with new batteries!!:(:( any ideas usually after fiddling with it then it work but not this time and i need it!
Hi,the problem is obviously from the internal battery contact of your device,or a the cord that delivers power to the unit is broken,you can take apart the stethoscope and fix it,but as a warning,the litmann 4000 is a very fragile and sensitive electronic stethoscope that requires high technique and expertise to fix,so i will suggest you contact a qualified stethoscope technician,so you don't end up ruining your stethoscope.
Thanks and take care
May 20, 2010 | Littmann Stethoscopes Littmann Lightweight...
There is no sound coming from the ear of my stethoscope. Do you have any suggestions?
First try new ear buds...they do get clogged just like ears! Next, replace tubing...it gets dry and will get fine cracks that are to even notice unless you are looking for them Littmann tubing does not contain latex...it does need to be conditioned with Armoral. I just found that out...after using mine for 7 years! OR>>>>buy a new one !!!!
May 13, 2010 | 3M Littmann Cardiology III Stethoscopes -...
Hello. Here is the manual http://www.wms.co.uk/Documents/product_pdfs/Littmann_Cardiology_III_Stethoscope_Instruction_Manual.pdf
You will see that the unit has a 5 year warranty and requires regular cleaning and maintenance in order to work properly. IF you can not tweek it so it will work by flipping the diaphragms then send it in for repair. the address in at the end of the manual. Joe
Mar 21, 2010 | 3M Littmann Cardiology III Stethoscopes -...
I have electronic littmann 3000 stethoscpoe, th plastic part came off th metalic part, I could not put it toghather, ? help!!!
Due to the specil adhessavis involved these products are not ment to be repaired. and if so thay must be certified by the m.i.a.
Sep 22, 2009 | Littmann 3000 Electronic Stethoscope Navy...
Can't turn diaphragm to bell - seems stuck?
Jan 21, 2009 | 3M Littmann Select Stethoscope
3M Littmann Cardiology S.t.c 27" Stethoscope - Available In All Colors Logo
Top 3M Health & Beauty Experts
Tom Bullen
Tom Bullen
Level 1 Expert
Tom Chichester
ray gallant
Are you a 3M Health and Beauty Expert? Answer questions, earn points and help others
