Question about Refrigerators
GE Refrigerator MODEL# GSS20IEPH BB Making High Pitched Ratteling Noise
My refrigerator makes a high pitched rattling noise every now and then and goes on sometimes for over 10 mins. I made a video of it to capture the noise. https://plus.google.com/u/0/photos/109270232266363851173/albums/5817864862778801249?authkey=CLGfkIOB5_L6bg
  • patb Dec 07, 2012
    Noise is coming from the back left bottom (If you are looking at it from the front)
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Frigidaire refrigerator only 6 months old making high pitch noise constantly after door has been opened. What is causing this?
Hello friend, thank you for your post!
Based off the information you have provided your Frigidaire refrigerator is making high pitched noises after the door has been opened. With our current refrigerators the new modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound. If you feel that further assistance is needed please contact your manufacturer for any warranty coverage. -Matt
Feb 02, 2016 | Frigidaire Refrigerators
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Fan in top of the refrigerator is making a high pitched whine when running
The high pitched noise is likely a bearing on the fan motor going out. You should replace the motor soon as it may fail completely.
Oct 18, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
High pitched noise
Then you will need to stop the fan and see if the noise is still there. If yes then its in the compressor. If it goes away then replace the fan
Sep 08, 2009 | GE Refrigerators
High pitched sound from fan
were is the fan making the noise if it in the freezer and making noise check for frost eany frost you may have defrost problem if it is in the refrigerator change fan if is the condenser fan change
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Refrigerators Logo
256 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
