Batery no charger
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Dec 04, 2012
Power button
try taking out the batery, and disconnect the charger. then press the ON button for about 30 seconds. put the batery back in place and try starting it up again. hope it works, it did for me :)
Sep 26, 2013 | ASUS K40IN-A1 Notebook
BATERY NO DETECT
If that is not a DELL charger then it was made that way. Dell is proprietary and wont let 3rd party companies make power units that charge and run the computer at the same time. IF it is a Dell charger then the battery is most likely bad.
Jul 23, 2012 | Dell Inspiron Mini 10 Notebook
Battery malfunction. both lights flashing on charger.
your batery has shorted you need a new batery I sugest you get another tool with same bater and charger just the batery alone will almost 1/2 this much
Oct 24, 2010 | Ridgid 18v Drill R86007 Rigid
I can't find where to conect the batery charger to the batery?
The battery is located under the seat. You can connect the charger directly to the battery there or you can connect the positive battery charger clamp to the post on the starter and the negative charger clamp to a good frame ground.
Good Luck
Steve
Oct 22, 2010 | 2003 Harley Davidson FLSTC Heritage...
My iphone is not charging I have tried different chargers and made sure nothing is stuck in the connection
is your batery is new?be sure that your batery is new because sometimes there is the problem.
2. Open the unit if you can and investigate the foot of the charger input ( the slot where you are inserting the charger connector/plug).Look on it if there is a loosen soldered foot and re-solder it to fix.Almost all of the time there is the problem due to always shagling everytime you perform charging.
Nov 01, 2009 | Cell Phones
K550i charging problem
in sony k550i mobile phone battery will not charge through monile charger i will check the charger but it is ok. when charger is connect to mobile then show on charging box make a charge but achually charging is dcressing.
Oct 17, 2009 | Sony Ericsson K550i Cellular Phone
Cant get my hitachi dz-acs3 ac adapter battery charger to work
the light will not come on when it is plugged in and the batery is set in the charger to charge, even with the dc out power supply the dvd cam will not work, could the charger go bad? does this happen often?
Sep 15, 2009 | Hitachi DZ-GX20A DVD Camcorder
Hi, I have a Ryoby charger number 1423701 but I
your batteries have possibly developed a memory and are probably shot or it may be the charger local toolstore should be able to test them both.Which ever one is bad it will cost more to buy a charger and battery than it will to buy a new drill .whatever you do ask the shop people how to stop the battery from developing a memory or if you want to come back to me when you have them fixed up I will be happy to tell you.please let us know how you get on ,thankyou
Aug 10, 2009 | Ryobi Multi-Volt Battery Charger
Computers & Internet Logo
David Payne
David Payne
