Question about Refrigerators
GE Refrigerator(Medallion) Mod.L17JCFRW-5 (manufactured by Camco) 1992
Freezer unit works well. Refrigerator section too cold. Temp. control for freezer adjusts properly. Frig. section temp. stays same (very cold) even when set at minimum. Frost Free works well. Housing for freezer dial removed and cold air supply from freezer to frig. works properly. Cover for frig dial removed. All wires connected. What do I do next. It has been an excellent unit for 20 years and I don't want to buy a new frig for a few more years.PS I can't afford one right now.
  • 2318 Answers
SOURCE: kenmoore 76523 ss bottom freezer, freezer works, refrigerator does not
Here is some additional info that could be helpful.
Click HERE
Posted on Feb 22, 2008
  • 117 Answers
SOURCE: I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Posted on Feb 19, 2009
SOURCE: freezer freezes, refrigerator is 55 degrees
All refrigerators also have a return air vent. You need to make sure this is not blocked by frost, the units own foam insulation or even by product placement. You should find it behind the crispers in the bulkhead between the freshfood and freezer compartments. You also want to verify the supply duct behind the damper is not blocked.
Posted on May 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: frost in back of frost free freezer, ice maker not
Whats happening is the defrost heater has failed. It is causing ice to build in the freezer and that is stopping ice production and fresh food chilling. Solution: Remove panel to evaporator and replace heater. Use hair dryer to melt ice. I have your repair manual: HERE
An air conditioning heating and ventilation expert named Dr Z normally makes HVAC videos but his neighbor's ice box did the same as yours and he had a chance to check it out and made this short film.He calls it his HVAC Refrigerator repair I thought it was pretty cool, cause it gives a good idea what is involved in this repair. HERE
Posted on Feb 07, 2010
Jennuwine
  • 23 Answers
SOURCE: Freezer not freezing frig not
Could be a couple of different things,
Defrost Heater,
Defrost Thermostat
Damper Assy
Here is a link to try for the items and breakdown
http://www.repairclinic.com/Appliance-Parts?s=t-PSS23LGSA+WW-%3d%3dc24
Sorry we could not help with the actual purchase of the replacement parts, Good Luck"
http://stores.ebay.com/Discount-Appliance-Parts
Posted on Sep 16, 2010
Refrigerator section which is on the top is not cooling, however the lower freezer section is working and making ice. Fan in refrigerator section does not seem to be working. Maytag mod#mbf2254HEW
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. The fan should spin freely when you spin it. You can check the fan plug for voltage to see if it's getting power with the door switch pushed in. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Dec 26, 2010 | Maytag Refrigerators
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Freezer does not get as cold as the setting made but refrigerator
If the unit is working correctly, it could be that you are trying to adjust the freezer with the wrong knob. The fresh food section is cooled by forced air from the freezer and can get about as cold as the freezer if not adjusted correctly. The thermostat its self controls only the temp in the freezer. Some times telling which is which is confusing. Here is the best way to tell the difference.
The knob that will turn the unit off is the thermostat. The other one controls how much air can be forced into the fresh food section. The thermostat should be adjusted to where the freezer stays around -10 degrees. The other knob should be set so the the fresh food section stays between 35 and 38 degrees. If this does not help or if you find that there is indeed a problem with you unit, please get back with me and I'll be glade to walk you through diagnosing the problem.
Please post a rating if solution is helpful. Thanks
Aug 21, 2009 | GE Profile Arctica Stainless Steel Top...
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
The temperator is uneven
Our side by side GE model # GSS25SGPESS is not cold on the food side. the temp in the refrigerator is 48 degrees.
Apr 18, 2009 | GE GSS25SGMBS Side by Side Refrigerator
My refrigerator is too cold
sounds like you have a defective temparture sensor
Apr 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Wow, so you dropped some money into it, eh? I would take a look at the damper door asslb(DIFFUSER). located at the very top left of your refrigerator section in back. It has a motorized door that opens and close's and it may be stuck open. More than likely it is broken and needs to be replaced. GOODLUCK!!!!
FYI: All your cold air in your refrigerator comes from your freezer!
Dec 17, 2007 | GE Profile PFS22 33" Artica French Door...
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
