Question about Kenmore 62802 Electric Dryer
My Dryer will not start. Model 110.62802100 Kenmore
I had a load of towels in opened the door to check them. They were not dry yet had it for running for 60 minutes. Closed the door reset for another 40 min and when i pushed the start botton it turned on for a second then shut off. Will not restart. Had the start and door switch tested and they work. Is the motor bad?? Also there is a YELLOW AND RED wire just hanging there and they said its a Moisture sensor wire but I dont think this dryer has one on it. Could that be the problem??
    President:
  • 1,214 Answers
Does the drum turn when you press Start? If so, the motor is not bad.
I am having trouble finding a wiring diagram, but I can not find a moisture sensor in the parts listing. BUT, there should not be any wires just dangling, unless the are tagged as to their purpose.
I suspect one of the following (if the drum turns)-
1) Failed thermostat
2) Failed thermal fuse on heat elements
3) Failed over temp thermostat
4) Failed heat element
Please reply your findings and we can help further.
Posted on Jan 19, 2009
Where is reset button on back samsung steam smart care dryer
clean the lint trap its suffocating air flow is blocked somewhere
consult manual
contact manufacturer
use a clothesline
Nov 10, 2016 | Samsung Dryers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
Everythings dries fine in my Kenmore dryer except for towels. It takes 2+ hours to dry a load of towels. What could be the issue?
Make sure that the moist warm air from the dryer can escape from the room where the dryer is located and that the Lint filter is clean and, if fitted, the air control vent is fully open.
The dryer needs to get clean fresh air with little or no moisture tro work properly: opening window/door to let the excessive moist air escape will help.
Hope it helps!
Sep 23, 2011 | Dryers
Dryer is taking too long to dry, can the element be worn out? whirlpool, thin twin heavy duty, large capacity
If it heats the element is good. Most likely cause is bad ventilation. check the vent on the outside of the house while dryer is running to make sure you are getting plenty of air flow. If you want to check to make sure its working properly general rule is 6 towels should dry in 60 minutes.
Sep 20, 2010 | Whirlpool LTE6234D Top Load Stacked...
My Kenmore dryer does not get hot enough to dry a load
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the door opening) and let me know. I hope you find this information helpful.
May 31, 2010 | Kenmore 62802 Electric Dryer
How long should it take to dry a load of towels with a electric dryer ?
Nice thick towels at a full load should be about 50minutes.
When was the last time you had the dryer exhaust cleaned, a poor air flow will cause the dryer to be less efficient. This will also make it safer.
Feb 11, 2010 | Whirlpool LER5636P Electric Dryer
Takes 2-3 times running to dry a load of towels (5-6 towels) dryer is hot but not drying
There is blockage in the venting system. Check from the blower wheel to the outside. It is blocked somewhere.
Eric
Oct 14, 2009 | Kenmore Dryers
My kenmore dryer 110.96564120 will not run
if it has light does it work when you open the door?
if not its a power issue check the outlet
if it does come on you probably have a bad door switch
Oct 06, 2009 | Dryers
Kenmore 62802 Electric Dryer Logo
155 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
