Question about Cell Phones
The screen of my samsung model sph-M575 went blank what can i do to fix it?
Today in the morning it was perfectly fine but then later on it went blank. Everything works fine except the screen is white I can call or text but as I said my screen is white. Need help!
5 Suggested Answers
NickBeamAA
  • 53 Answers
SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
Posted on Sep 09, 2007
MNfisherman
  • 11896 Answers
SOURCE: white screen on samsung sch-r450 messenger frm water damage
the only possible thing you could do yourself is to remove the screws, pull it apart and try to blow dry. That's the only thing you can personally do.
Posted on Apr 21, 2009
astruttman
  • 45 Answers
SOURCE: Samsung SPH-M300 display screen is white
take the battery out and place it back in the phone that usually works i work for sprint customer support not technical support but that seems to do the trick alot it resets the phone if that dont work dial *2 from ur mobile device to call technical support
Posted on Jul 06, 2009
SOURCE: The screen on my My Samsung SPH-m510 just went
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Posted on Jul 23, 2010
How do i unlock and activate my samsung sph m575
you may wish to visit a samsung service center in your area.thanks
Jun 28, 2011 | Cell Phones
Need the manual for sph m575
The manual for the sph-m575 is the same as that for the sph-m570. You can get this manual here: http://www.samsung.com/us/support/supportDownloadCenter.do?prd_ia_cd=N0000000&prd_mdl_cd=SPH-M570ZKASPR&prd_mdl_name=SPH-M570 .
I hope this helps.
May 15, 2011 | Cell Phones
Sony Ericsson W580i screen went blank
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
Apr 20, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Screen went blank
The part that is bad is the Ribbon flex cable that geos from the main board to the LCD board. Over time the cable becomes chaffed and will lose continuity between the traces. It can be fixed with
Tessco Part #: GH97-07715A
It does need to be soldered on the LCD side.
Or it is liquid damage
Mar 12, 2009 | Samsung SPH-m520 Cell Phone
Samsung sch u740 problems
awzone - get your phone to the nearest repair store and have them service the phone if you wait o long the board maybe to far gone to be saved.
May 15, 2008 | Samsung SCH-u740 Cellular Phone
Samsung 753s monitor problem
try to check the B+ line voltage. Check the FET and resistors on this line.
Mar 17, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
My samsung digimax 503 has a white screen!
Oh my gosh this really works! Our screen went white, we hadn't dropped it or anything. The camera still worked fine but we just couldn't see what we were taking a picture of. We tried this solution and now we can see the picture through the screen perfectly. THANKS for posting this!
Nov 09, 2007 | Samsung Digimax A503 Digital Camera
BIG problem. PLZ help!!! :(
The Samsung YP-F1 has a reset button located under the black Samsung cover plate. It can be gently removed via a finger nail or mini flat blade screwdriver. Once plate is removed a hole labeled reset will be seen. Use something like a paper clip and press in. MP3 will power down/reset. MP3 data is also retained after reset.
Apr 03, 2007 | Samsung Yepp YP-F1X MP3 Player
Cell Phones Logo
107 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
