Question about Dryers
We have an older GE dryer we use at the lake cabin. My wife put a heavy matress cover in , it ran a few minutes then cut off. Now it will not come back on. Did she burn the motor up. I checked the breaker.
  • 1 more comment
  • Roy Carroll Dec 04, 2012
    DDE5100MCLWH
    I should say, it's like there is no power to the dryer. Nothing turns or comes on.
  • Richard Roth
    Richard Roth Dec 04, 2012
    First, check to see if the door switch makes a "click" when you push and release it. If it does, then the motor is bad and needs to be replaced. Here is the part to order.http://bit.ly/XmDBgM
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the complete model number of your unit?
Posted on Dec 04, 2012
  • 330 Answers
SOURCE: HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Posted on Jul 06, 2008
  • 117 Answers
SOURCE: Kenmore Heavy Duty Dryer
If the dryer is still powered on but the motor stops, it sounds like the over load in the motor is cutting out and the motor will have to be replaced.
Posted on Feb 26, 2009
  • 4 Answers
SOURCE: Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Posted on Jan 28, 2009
SOURCE: whirlpool dryer model LER7646EQ1
DOES NOT DRY VERY WELL , BURNER COMES ON THEN SHURS OFF
Posted on Apr 10, 2009
  • 1122 Answers
SOURCE: Dryer does'nt run. checked breaker, thermal fuse, starter relay, timer stops when door is opened, starts when closed?
2 more things could be wrong,check the blower box to see if you have a thermister thermostat on it,check that with your omns meter,the other thing is the motor is no longer strong enough to turn the drum and it heat up and tips off,let me know what you find-mike
Posted on Apr 22, 2009
How do you get to the belts on a ge 8 cycle heavy duty dryer. It's an older appliance.
Remove the top/cover and then remove the front assembly and you will have the drum and belt in front of you.
Jan 30, 2015 | GE Dryers
How to change 2004 mdx cabin air filta
The older the Acura/Honda, the more difficult this is. The 2nd generation MDX takes 2 minutes to replace, yours isn't that easy. 2 philips head screws hold the glove box hinges in. Pull the right kick panel cover off first, to get access to the right screw. If this is the 1st time it has been replaced, cut out the plastic in front of the bracket that holds the glove box. There are slots on each ent to make it easy. Then some unscrew the bracket. Remove it and the CAF cover is right there. Have patience, getting the 2 hinge screws back in takes some finesse. There is a short cut to this job, but I would have to show you.
Jun 28, 2014 | 2004 Acura MDX
Doesn't clean dishes. Have ran it on heavy duty load aas well as normal. dishes still dirty and had to do by hand.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 08, 2011 | GE Dishwashers
GE refrigerator model GSH25KGRB # HG256690 NO WATER OUT DOOR.
I use a hair dryer to defraust the door. This refrigerator is very sensitive to tempature change. When it gets cold out and you have the tempature on high, the water freezes in the door.
I cover the opening of the freezor with a piece of plastic cut to fit. I tape it in place with blue tape. I tape the door switch down so the you can test the water to see when it is running again. I use the hair dryer With the door open I concentrate the heat on the right side center section. It usually takes about thirty minutes. I put a glass in the water compartment and I try the water every few minutes until it flows. Finally, I run the water for two or three minutes after it starts to flow to make sure all of the frozen water is clear. Thom
Sep 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
RE: ge gsd2000j01ww When I opened my dishwasher after a run... I found a white large belt (rubber band like) on the top shelf. I have no idea where it belongs
At the bottom of the dishwasher (older GE) you see a plastic cover with rounded corners and two 'grill' shaped sides. Remove the screws (1\4) and lift the cover. There might be a huge amount of grey clog and dirt stuck on the inside already. Remove it with a fork or long brush and rinse it. There is another grill in the water hole pull it out and clean it as necessary. You may also want to reach into and check the water hole for debris. If you are not comfortable doing so you can remove the water by pushing an old towel into the hole first. Once all parts are clean put them back in place and fix the cover with the screws. Pour 2-3 table spoons of bleach into the machine and let it run twice on heavy duty cycles.
Jul 24, 2009 | GE 15" Laundry Pedestal for Horizontal...
Gas dryer burner cuts off after a few minutes of use
Your gas solenoid coils are bad. Replacing them will solve your problem.
May 17, 2009 | Whirlpool Dryers
Drier keeps shutting down.
I had the same problem, they wear out in the rear bearing slot and drag on the front slides, So I bought Sears heavy duty model and it was was running better than ever until my wife took it away when she left me. Hope this helps
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
GE Dryer Will not start
possible door switch broke when uou shut it back also ck wiring diagram under console for thermal fuse in motor circuit
Jul 24, 2008 | Dryers
Spark continuously on
If you have recently cleaned it, you may have gotten moisture behind the knobs and into the spark switches. Be very careful not to let moisture get behind knobs. Very dangerous. If this is the case, they may dry out themselves and stop sparking. If not you may need to replace a spark switch behind knob.
Nov 20, 2007 | GE 30 in. JGP336 Gas Cooktop
Dryers Logo
62 people viewed this question
Top Dryers Experts
