Question about Lexmark X2500 All-In-One Printer
Error message for printer says "invalid cartridges" makes no sense to me. They've been fine up until today
All of the sudden my printer is giving me an "invalid cartridge" message, and i don't know why. The cartridges are the right ones, and they are 3/4 full and they've worked fine up until today. I've tried unplugging everything and plugging it back in. I've tried uninstalling the software and reinstalling it. I've tried taking out the cartridges and wiping them off, but nothing works. What could be the problem?
SOURCE: lexmark x2500 invalid cartridges
I am out of ink for my printer the numeber is 28 black 29 color
Posted on Jan 01, 2009
SOURCE: Print Cartridge Missing
had cartridge refilled put back but comes up no cartridge
Posted on Mar 23, 2009
SOURCE: lexmark x9350 printer gives error message #1203
I logged into Lexmark's web site and checked their printer support page. It said that if you get error message 1203 your ink cartridge has leaked fluid. In order to find the right cartridge, do the following. Remove both ink cartridges, put in one, turn off the printer, turn it back on and if you get the message 1203 that's the cartridge with the problem. I did not get that message. I turned off the printer, put in the other cartridge, and turned it back on. Sure enough, I got the 1203 message again. (I had cleaned the wrong cartridge before). I removed the leaky cartridge, cleaneded it (making sure I did not leave any residue) and put it back in the printer. It worked!
Posted on Jun 13, 2009
  • 156 Answers
SOURCE: New cartridges do not work in Lexmark 3550 Printer
Are you sure that they are installed correctly, seated, etc.? Do you have the right cartridges? Have you aligned them?
Posted on Jul 06, 2009
  • 232 Answers
SOURCE: refilled ink cartridges at Walgreens, printer won't recognize
Hello!
28 and 29 are not meant to be refilled. They can physically be refilled, but they won't work. That is because Lexmark has put in a smart chip that doesn't allow refill.
You need to buy 28A and 29A or 34 and 35, those cartridges can be refilled with no problem.
If you find my answer helpful, please vote. Thank you!
Posted on Apr 16, 2010
All of the sudden my printer is telling me that my cartridges are "Invalid"
is you machine hooked up and have internet then it might have gotten new firmware and if you are using generic cartridges this can happen. try oem lexmark cart.
Jul 04, 2017 | Lexmark X2500 All-In-One Printer
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
Hp4355 print catridge error
Each cartridge having printing life, as long as cartridge health condition is good it won't gives any trouble. Subjected series printer having mono & colour cartridges,1. Remove both cartridge from the printer 2. Switch on & wait till message appears for insert the cartridges..3. Insert mono(Black) cartridge, close the door & wait till message appears on screen. If message appears same as cartridge error mean that mono cartridge is faulty replace it, if message appears like insert another cartridge, it's confirmed that colour cartridge faulty.. Replace it..
Apr 28, 2012 | HP Officejet 4355 All-In-One InkJet...
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
My printer was working fine and suddenly when I tried to print a message came up "remove and check cartridges". I did that and continue to get the message. I turned off the printer, unplugged...
hi
Did you make sure they were not expired when installed in the printer?
Still what i can suggest you to do is. Remove the cartridges clean the contact on the cartridges and also in the printer. And turn off the printer. Now turn on the printer and wait for the printer to show error for cartridges and now you can install them back and try,
Jul 19, 2011 | HP OfficeJet 6110 All-In-One InkJet...
After I press the green start button, I can hear the rollers making a whirring sound for a few seconds, (doing their cleaning bit) then the amber trouble light goes on. I can' t get a print in other...
Hello Jra,
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jun 22, 2011 | Canon Pixma iP2600 Photo InkJet Printer
"invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Feb 18, 2009 | Samsung CLP-510 Laser Printer
Error message: invalid toner yellow
If the toner is empty it will display this message and the only way I know of getting rid of it is to replace the cartridge. They do make refill kits with extra chips so you can cut the old one out and sticky tape another on. As for a clearing code I am unaware of one for this unit as the information is store in the toner cartridge.
Sorry
Jan 06, 2009 | Samsung CLP-600N Laser Printer
Lexmark X2500 All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
