Question about Music
Replacement power supply digitech s100 - Music
4 Suggested Answers
  • 1137 Answers
SOURCE: i need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
Posted on May 26, 2009
  • 5603 Answers
SOURCE: Power supply received an overload. Replaced supply
Make sure the replacement power supply was EXACT same ratings and polarity.
Posted on Sep 10, 2009
Testimonial: "Should be wearing glasses all the time as this power supply is AC, I assumed it was DC"
  • 5603 Answers
SOURCE: my digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Posted on Sep 16, 2011
Is a Harmon ps0913b 240-au-b power adapter, suitable for a Digitech Live Harmony pedal
Consult the manual for the rating of each power adapter to compare. The units will also have the specs needed printed next to the power input jack, but the manuals will be more detailed.
Sep 24, 2015 | Music
My digitech 4 harmoniser is cutting out, have sent for a new power supply adaptor to see if this is problem any other ideas?
Most likely it is the power supply, but if you have a unit that uses the same voltage, you may want to try it. Another possibility would be the power input jack or where it is soldered to the board. If you're not comfortable working on those elements and the PS doesn't work out, take it to the shop.
Mar 06, 2015 | Digi-Tech Digitech Vocalist Live 4...
My digitech rp 500 has power supply but it won't
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
NO power light from Digitech Vocalist 2 live. Power supply OK. Is there an internal fuse. etc? need tips to troubleshoot.
Check that your power adapter is for 9 Volts AC (not DC like most pedals) and is rated at 1300ma or more.
Dec 23, 2010 | DIGITECH VOCALIST LIVE 2
My DigiTech RP90 expression pedal isn't working at all
If you are getting no display after you try powering up properly check the plug end of the power supply with the supply plugged in with a volt/ohm meter. You should get a reading of 9volts. If you don't ,your power supply is not working. Sometimes the wire breaks where it goes into the supply and sometimes where it goes into the plug. Your power supply jack may be broken where it is soldered to the circuit board. If the unit has power you can do a factory reset. The procedure is on page 34 and 35 of the owners manual that you can download for free here:ftp://ftp.digitech.com/pub/PDFs/Manuals/RP90/RP90Manual18_0490_A.pdf Let me know if this helps.
Nov 26, 2009 | Music
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
I need the pin out details of a digitech rp6 guitar effects pedal
Digitech RP90 Expression Pedal
Same thing happened to me but i didn't drop the pedal.Try to recalibrate the pedal cause mine worked after that.Look in the Owner's Manual at the recalibration section.Hope this will work for you.Good luck with it!
Mar 29, 2009 | Music
Music Logo
121 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
