Question about Philips 40PFL7705D 40 in LCD TV
How to return philips 40pfl7705d to factory settings
    Top Expert:
  • Philips Master
  • 14,553 Answers
I don't think it has a factory reset but Philips would know if they or a authorized service center will talk to you----both are generally not very helpful.
Posted on Dec 03, 2012
How to format and return to factory settings?
I would guess its in settings i had a vibe at one time
Sep 28, 2015 | Philips GoGear ViBE SA1VBE08K MP3 Player
I want to return my computer to it's factory settings:
to return your computer to factory settings:
You can try this: http://www.ehow.com/how_6590939_return-computer-factory-settings.html
or you can turn off your PC, keep pressing F8, insert the reinstallation disc, and continue.
Jan 19, 2013 | Computers & Internet
40 in philips turns itself off and on randomly
There is a loose contact inside the board. Better refer it to a skilled and qualified service technician.
Jul 28, 2012 | Philips 40PFL7705D 40 in LCD TV
Philips 40pfl7705d/f7 tv has no picture but has sound
Possible it can be failure of the t- con driver board but it is necessary that you measure the voltage on the boards.
Check for visible leaks from capacitor , burnt driver or IC or resistance that can lead to the fault. If not the board must be replaced.
Jul 04, 2012 | Philips 40pfl7705d/f7 40 Led 120 Hz Lcd...
What brand of a router to use?
Hello
You can select any brand router. Select one of a reputed company, which give you warranty.
Mar 05, 2012 | Philips 40PFL7705D 40 in LCD TV
Key lock on
Hello
Your Dell tV can be unlocked by reseting it to factory reset.
To reset it to factory reset do the folloing.
Enter the TV main Menu.
Select Factory Reset to return the TV Menu settings to the factory default values
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Feb 01, 2011 | Dell W4201C 42 in. Plasma HDTV
HI, I am am having problems with my Philips GoGear Flash audio player SA2625. When ever I turn it ON, all it says is "Philips" then it turns off. When ever I plug it in it says "OK to disconnect", the...
I found a restore fix by pressing the return button while plugging into a PC with philips device manager open - the MP3 player then was restored to factory defaults :-)
Jun 16, 2010 | Philips GoGear SA2625/37 MP3 Player
Will pushing reset key erase my music?
Most Likely YES! The reset key feature is designed to return the player to a factory state setting for varius reasons including but not limited to: data corruption, need of quick reset, etc. I hope this helps! Good Luck!
Jun 11, 2009 | Philips GoGear SA3020/37 MP3 Player
Ref monitor
Yes, after looking around this seems to be a common issue with this monitor. You can try re-setting it to factory settings.
You can download the User's Manual Here.
Sep 13, 2008 | Philips 170B4MG 17" LCD Monitor
Forgot password for hd dvdr3460h
hi... the default password stated in user manual for my DVDR3460H, is 3308.. if you've changed it to personal pin - use the restore factory settings option and it will return to the default pin and start again..
hope this helps, good luck
debij75
May 18, 2008 | Philips Televison & Video
Philips 40PFL7705D 40 in LCD TV Logo
262 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
