Question about Amana NED5200TQ Electric Dryer
Fuse wires touched metal now dryer wont work - Amana NED5200TQ Electric Dryer
    Top Expert:
  • Amana Master
  • 9,472 Answers
Remove the back panel and check the thermal fuse for continuity. Here is the part to order in case it is bad.
Posted on Dec 04, 2012
Well i wanna know the wires of the timer touch a metal cover and did a short cut my question is do i need to change the timer of what else do you think could be the problem a fuse ?
you'll have to call in a tech to check it out or replace the dryer,nobody can answer that question without being there and checking the dryer with a meter,if the wires from the timer touched metal and i can't see how that happened unless someone worked on it without unplugging it you could have cooked just about any wire or part that those wires go to but then again you could change the timer and it could work but you have to check it with a meter first,that timer cost around 140 dollars,to much money to just guess at.
Dec 10, 2012 | GE DVLR223 Dryers
Wire touched bare metal and now it wont turn on.
did you check the fuse for the stereo? sometimes if the wires touch it will burn out a fuse.
May 11, 2012 | Dual Xr4115 Mechless Digital Media...
Wed6400sbo dryer wouldnt heat now start button wont work
check thermal fuse. Testing a thermal fuse
Note: Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel. Testing a dryer's thermal fuse is much like testing its thermostats. Follow these steps to replace your dryer's thermal fuse.
The wires leading to the thermal fuse are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you.
Set your multimeter to the R X 1 setting. Take each of your meter's probes and touch one to each terminal. You are testing for continuity, and you should receive a reading of either zero or infinity. At room temperature, testing the thermal fuse should produce a reading of zero. But if a thermostat is tested when it is heated to its limit, a reading of infinity should be produced. We strongly recommend that you test your thermostat at room temperature.
If the test you conduct with your thermostat does not produce these results, then you should replace the component.
Dec 09, 2011 | Whirlpool Dryers
Our dryer wont start and the outlet doesnt give us power. The circuit breaker works until we plug the dryer in. Please help
most likely the heating element is shorting out or a wire is touching metal in the dryer or you have a problem with the house electrical,unplug it,pull it out and remove the vent line and the back panel,first check the connections where the cord connects to the dryer and make sure that's ok.if that looks fine go to the heating element connections down on the bottom right hand side,pull off the wires going to the element,check the element with a meter or make sure the wires aren't touching anything and plug it back in,if the fuse doesn't pop change out the heater,if it does pop again call an electrician to check the house circuit or and go through the dryer to see if any of the wires are shorting out,
Sep 22, 2011 | Whirlpool LER4634J Electric Dryer
Myy dryer will not turn on. It was working fine did a load of clothes and now it just wont turn on again. I checked the breaker and it is on.
First check the door switch to see if it appears broken.
If not, unplug the dryer and remove the back. On the bottom left you will see a white fuse with two wires going to it. Unplug those two wires and connect them together. Either tape this with electrical tape or make sure it is well away from the cabinet and will have no chance of touching metal. Plug the dryer in and see if it will start, if not replace this fuse (part #3392519).
Feb 18, 2011 | Whirlpool LER4634J Electric Dryer
Dryer not getting hot
First ck and make sure you have 220 volts to the dryer. It will run on 110v if one side of the breaker is bad. The other culprits are a limit switch heating element or thermal fuse. If you have 220 volts and the dryer runs just does not heat first turn off the power to the dryer and unplug the dryer from the outlet. Pull the dryer out and remove the lower back panel it is held on by several 5/16 hex screws. (not the back plate on the switch panel) Remove the back and your heater is on the lower right hand side and is inside an metal shell. The thermal limit is also on the metal shell and will have several wires running to it. And if you trace the wires from the element and this thermal limit it will go to the thermal fuse it is on the lower back slightly to the right of the dryer and has two wires run to it and is about the size of a dime or smaller. Unplug the two wires from the termal fuse and hook them together with a papper clip or just tape them together make sure it doesn't touch metal. (this will short it out) and then plug up the dryer and try it to see if it heats you do not need to hook up the vent. (make sure not to touch the back of the dryer and especially any exsposed wires. If it heats up your thermal fuse is bad replace it. If it does not you should check your heating element first unplug the dryer and reattach the wires to the thermal fuse. Then the heating element metal shell should be removed. First unplug the wires to the heating element and thermal limit switch and mark them so you know where they go. Next remove the screw at the top of the metal shell pickup and pull back on the shell to disengage it from the dryer. You can then remove it and inside is the heating element it is attached to the shell with 5/16 hex screws. Remove the screws and pull the heating element out of the bottom of the metal shell. Look closely and you should see the heating element break. The element is a coiled wire and when it heats up the wire actually grows in length and when it is off it cools and shrinks this causes fatique and the wire breaks over time. If the wire is broke replace the element. Look very closely use a pencil to move the wire slightly it is sometimes very hard to see the break. If broken replace the element and make sure not to touch the new element with your fingers this can case premature hot spots which causes the element to fail prematurely. If the wire is not broken then the thermal limit attached to the metal shell that holds the heating element is bad. Before doing any of the above you should look at all the wires in the back of the dryer and look for burnt or broken wires replace or repair them and check the dryer before any other repairs should be entertained. Before replaceing the back on the dryer clean all of the lint out of the back of the dryer and out of the dryer vent. This is very good insureance for the future of your dryer. Good Luck and I hope this is useful.
Sep 28, 2010 | Kenmore Dryers
Dryer timer works but start button doesn't and wont turn on
I would check the door switch. If it's bad, the dryer will not run. You can check it by taking the two wires going to it and tying them together. Be sure to tape them together so they will not touch metal and short. If the dryer runs, replace switch. If not you most likely have a bad thermal fuse and or thermal cut off.
Oct 12, 2009 | Kenmore Dryers
Dryer wont start on my roper dryer. Timer is working but wont start
Check for a blown thermal fuse. It's about an inch long and is located inside the rear of the dryer usually attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a blown thermal fuse. Sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Dryers
Whirlpool sport dryer wont start lights come on when you push start button sounds like its activating but wont start is it aproblem with the button not sending the right signal
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 04, 2009 | Dryers
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
Amana NED5200TQ Electric Dryer Logo
44 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
