Question about Intel D850MV Motherboard
PC want shutdown
My cpu fan want shutdown I has pull the power cable to turn off
  • Brian Perry
    Brian Perry May 11, 2010
    When you think you turn off your computer, it may not really be off. It may just be in suspend mode. If it is supposed to be off when it really isn't then you may have a problem with Advanced Power management.
  • Bill Speer
    Bill Speer May 11, 2010
    Why do you want your CPU fan to shut down? It should be running continuously as long as the unit is powered up. Are you referring to you turn off the PC and the CPU fan is still spinning?
    Sergeant:
  • 270 Answers
It is a usual procedure
Posted on Jan 12, 2009
Can't turn my a/c off Or fan. I hit theoff button & just changes settings. Other than turn the car off itself, I can't figure it out. Earlier in the year rebooting the car'd work. No more.
Laptop not shutting completely (Power light and fan stays on ...
www.tomsguide.com/.../laptop-shutting-completely-power-light-fan-stay...
3 days ago - I have to hold the power button for 5 seconds for my laptop to turn offcompletely. ... I tried removing my battery completely, and started the windows with my A/C adapter and then shut it down ... when i shutdown my pc , my pc has get shutdown but the power light in my cpu tower ... Can't find your answer ?
Nov 19, 2015 | Computers & Internet
Ibm thinkcentre cpu fan runs on high after shutdown
Open the Control Panel. Power Options, Change/Adjust power off settings, change Sleep and Hibernate to Never, set to High Performance. A reboot everyday will reset your computer.
Jan 18, 2013 | Computers & Internet
Hi, I have ECS mobo and its powering on but after 20 minutes it will shut off by itself or hang then when i tried to power it back on, the cpu will not turn on but it seems the fan is moving a bit just...
Your CPU Fan is faulty or not functioning properly. This probably is due to overheating of the CPU, and the System Unit will shutdown to prevent further damage to your Mainboard. Replace the CPU Fan.
Hope it helps.
Aug 06, 2011 | Computers & Internet
My compaq sr1103wm will not power up. Whan you turn it on it starts to boot for about 5 seconds. It just keeps turning on and off on and off on its own. Could this be a power supply problem or...
It could be "sort of" either. If the power supply fan is labouring or stopped, it will overheat very quickly and force a shutdown or blow a fuse. Because of the latter usually this will only happen a few times, and then perminently. If the cpu fan bushings are clogged with jam, and it is labouring, the cpu temps will shoot up and trigger a bios level shutdown. So you need to do some checking, and perhaps some cleaning. Usually if there are motherboard problems, you will get beeping indications of device checks. If there is no picture, then the vga card could be loose...but again, beeping for sure. loose power cord connect or worn - problems, not always a beep here. Check a cables and connections but the first checks are likely the root.
Jun 13, 2011 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Computer shuts down by itself
There can be many reasons of unexpected shut down of your system.Below are some remedies to solve it
Run an anti-spy ware and anti-virus utility to make sure that the shutdowns aren't being caused by a malicious program. If the shutdowns are infrequent, install a CPU temperature monitor utility to keep track of the CPU's temperature. If the CPU is overheating, or the shutdowns are frequent, then you will need to troubleshoot your computer's internal components.
Check any recently installed internal components to ensure that they are properly connected to the computer's motherboard. Make sure any new expansion cards or memory modules are securely seated in their slots, and ensure that the power and data cables are properly connected to any new drives.
Check for large dust buildups on your CPU fan. If the fan isn't effectively cooling your CPU, the overheating CPU will cause your computer to power off. Carefully pick away large pieces of dust with your fingers, and then spray the CPU fan with a can of compressed air to remove the rest of the dust.
Reapply the heat sink compound between the CPU and heat sink if the computer continues to turn off unexpectedly. Heat sink compound is a pasty substance that fills the space between the heat sink and processor, which increases the heat sink's ability to absorb heat from the CPU. But worn heat sink compound won't properly redirect heat away from the CPU. Power down your computer, disconnect its power cables and open the case. Unplug the CPU fan's power cable from the motherboard, remove the heat sink and fan combination from the CPU, and then apply the heat sink compound to the CPU--refer to your product manuals for details on reapplying heat sink compound.
Thanks .
Have a great day.
Oct 03, 2010 | Dell Inspiron 537s PC Desktop
Computer power ON/OFF behavior is not as expected!
Hi...
If all the parts of your computers are fined functioning. This is a CPU problem witch is no display. Try to disassemble the CPU remove the heat sink the CPU and clean and insert it again. When you are now inserting the CPU be sure that you will put a thermal past in the heat sink so that the heat from the CPU are absorbed. If the heat will not be absorbed it will cause overheating.
Good luck! Thanks for using fixya.
Regards
ICmanServer
Aug 21, 2009 | Computers & Internet
When i turn my computer on the monitor go out and flashes and the orange light on the front of the computer stays lit and the fans run constant
Check your cables first. Reseat your connection from cpu to monitor. and check power source and cable.
If not reseat or clean the edge connector of your ram module with soft eraser. But first shutdown your unit and unplugged to power outlet.
Hope this helps
May 02, 2009 | E-Machines eMachines Desktop PC
Cpu fan still running even the system was shutdown
Unplug your computer from the wall socket. Then the only power it will have is the battery that keeps the CMOS information. There will not be enough power for anything to run.
Don't forget to rate this solution.
Jan 19, 2009 | PC Chips P21G (881038000916) Motherboard
Random shut downs
Check the CPU fan it may not be spinning at the full speed or not turning at all. Check that there is not cable that is obstructing the fan blades. When the CPU over heats the machine will shutdown to save it from any damage. Then other thing to check is the power switch make sure that it is not sticky or stuck in. It also could be a memory issue but normally there will be a blue screen fault and audio beeps when you first switch on.
Try these Thanks J
Jan 17, 2008 | Systemax Ascent RTS A14 (980796) PC...
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Intel D850MV Motherboard Logo
24 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
