Question about APC 1500VA BX1500 8 Outlet UPS UPS System
Apc xs1500 beeps 4 times
Unit beeps 4 times every 2 minutes or so. the green light is off and the offline (amber light) is on. unit as new batteries. Unit is about 3 1/2 years old, it's been great till about 4 days ago. Thanks JM
    Filmmaker:
    Uploaded 5 video answers.
  • 45 Answers
Check if the unit has a breaker on the back and reset it. The unit doesn't seem to be getting power.
Posted on Jan 01, 2013
2 Suggested Answers
pravinbhavsa
  • 348 Answers
SOURCE: hace a APC XS 900 that said battery needs
disconnect one terminal of the battery then measure charging voltage betwen +ve and -ve it should be 13.8vdc for one 12v battery if charging voltage is not present then battery is ok then connect ammeter to measure the current in Ampere .take care it should be in series if current if no current then battery must ok opern the ups there is a charger transformer measure i/p voltage to transformer if not present then check i/p path if present then check diodes at o/p of charger if faulty replace it also check capacitor and regulator ic if faulty replace it your problem must be solved
Posted on Mar 14, 2010
Testimonial: "There is no way to check the water in the batteries as thry are sealed. I found out that after a load is applied it goes on battery for a few seconds "
APC SURT3000XL UPS
The fault indicator means that there is a fault in the circuitry of the UPS. It could be the control board or another part of the system. (If the batteries were bad, you would see the Replace Battery light illuminate.) If the SURT3000XL is under warranty, contact APC. The standard warranty period is 2 years for repair/replacement. Note: you'll probably have to pay for the shipping of the unit. If the unit is out of warranty, replace it with a new UPS.
I hope this helps.
Nov 13, 2013 | APC Computers & Internet
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
I have an Symmetra RM APC and there is an amber light showing and a beeping about every 30 seconds.
Hi Ewiesemann,
The amber light on the UPS usually means that the unit is 'on battery' -- meaning that input power is affected. Check to make sure that unit is plugged in and check to make sure that a breaker on a panel feeding the UPS power hasn't tripped.
Hope this helps.
Jul 28, 2011 | APC - UPS - Matix/Symmetra Enterprise UPS...
I have an APC XS 900 for about 1 1/2 now. I started getting a continuous beep with the overload light turning on. I could not get it to stop, even when the computer was disconnected. After reading the...
You need to reset the unit to recognize the new battery, I had same problem with one apc smart ups on the bench the other day.
On ours we had to turn off the unit unplug the battery wait 5mins
press the on key and hold for 20secs
reconnect battery
plug in to mains
and start as normal. We did this but still had very low battery time and the flashing lights, so we disconnected the comms interface, that sovled the problem.
It may work for your unit, suggest you check the manual before you try if you are unsure
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | APC Back-UPS XS900 (BX900) UPS System
What does it mean by the beep sound from the UPS ES 350 unit?
Ok, 3-4 years is a much as you can expect from an ups battery so replacement is indicated. The beeps are letting you know the battery is not able to keep up with demand. So either you have recently added to the system or the battery/s failing.
Apr 18, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Hace a APC XS 900 that said battery needs replacement, unit is about a year old. I replaced the batteries & it lasted about 2 hours & again says replace batteries. I know the new batteries are OK...
Mar 13, 2010 | APC Back-UPS XS900 (BX900) UPS System
It's an older unit that i just tried. When i plug
Try installing the software that is included with the unit. If you didn't get the software, I believe you can download it for free from APC's website. The software will typically give you the status of the batteries and let you know if you need to replace them. If you can't get the software, take the batteries out (keep note of the wiring configuration) and test each battery using a DC voltmeter. The batteries should read around 13.5 volts DC. If they are around or below 11.5v DC, it's time for new batteries. This model, if its the black 110v version, requires the RBC32 which can be found at: http://www.batteryinternational.com/apc-rbc32--f2.html
Good luck and I hope I could help.
Jun 27, 2009 | APC Back-UPS RS Battery Backup (apw...
Beep and yellow green light problem
It sounds like you may need a new battery. The batteries are continuously tested by the UPS and it could be that the voltage is passing one test, and failing the next which is resulting in the light flashing. You can test the battery with a voltmeter. It should read over 11.5 volts, if not you need a new battery set. You can get batteries from http://www.batteryinternational.com/ups-batteries-apc-batteries.html
Jun 20, 2009 | APC VS 500VA (VS500VA) UPS System
APC 1500VA BX1500 8 Outlet UPS UPS System Logo
507 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
