Question about Sony KP-61V85 61" Rear Projection Television
Sound no picture
When turned on a slight blue/green line at the top then nothing. bulbs are dim
  • scott baxter Dec 03, 2012
    Is this tv worth fixing? Ive had it 13 years. with no problem
  • SD Tech
    SD Tech Dec 04, 2012
    It may be---some parts are not available--I have a thought---if you open the rear cover above the boards is a metal channel that runs left to right--look for any signs of a white residue in it--these sets did have issues with Glycol leaking into that and from there down onto the boards under them, if find that retire the set and if see any clear liquid, even a tiny amount do not touch it--toxic stuff.
    Top Expert:
  • Sony Master
  • 14,553 Answers
A educated guess here (model is a rather old Sony) this set will blank or shut the tubes off if loss of vertical or horizontal deflection---the slight line at top suggests vertical
What I have done to confirm this is either use a scope and check for deflection or turn blue screen up slowly(blue is less likely to burn the tube screen) and see if just a line.
The set blanks the tubes to prevent a line being burnt instantly at normal brightness (all concentrated into a line) on the face of the tube.
If you are technical and have a volt meter you may be able to locate online a free copy of the service manual to check voltages etc.
Posted on Dec 03, 2012
  • 119 Answers
SOURCE: Sony KP-51HW40 No Picture, only sound
how many thimes does the light blink, it's an indication as to where you should start looking for the cause of the problem
Posted on Dec 21, 2006
vcrdr1
  • 53 Answers
SOURCE: Pink picture with wavy green and blue lines
start with convergence ic's probably stk 392-130 big black chip's on an alluminum heat sink. mark ALL connections with majic marker. check for bad solder connections. for god's sake be carefull
Posted on Mar 12, 2007
  • 2920 Answers
SOURCE: when tv is on it just loses all color but blue
the tubes are going out on you,probably time to replace them
Posted on Nov 04, 2008
  • 8 Answers
SOURCE: STARTS UP VOLUME COMES ON 5 SECONDS LATER NOTHING
Try this... it worked for me after 3 years of dead TV.http://www.fixya.com/support/t129700-green_flashes_tv_turns_off
Posted on Mar 04, 2009
  • 111 Answers
SOURCE: blue screen and red lines
crts are bad
Posted on Feb 05, 2010
Got the TV 4 free so lets start at that. Was a very poor picture so checked the guns saw the green/blue was very foggy and changed the CRT Fluid in Green and blue red obviously was fine. Now tv up and...
are the lines slightly curved and go from the botom to top across the screen. If so it sounds like retrace lines from the CRTs being turned up too far. You can add the pic by clicking the camera Icon next to where it says Insert below the text box.
Nov 03, 2011 | Philips 50P8341 50" Rear Projection...
I have a hitachi rptv model #43FWX20B and the picture has a red tint to it. Opened back up and red green and blue bulbs light up. red bulb stays bright while blue and green go dim to bright as tv plays....
Howdy;
Since you don't have any white lines with the red screen/picture I would say that the red bulb (CRT) is conducting too much. There is an adjustment control for that. The 'sceen' control is behind the speaker cover and service cover. Turn red screen control slightly to the left until you get a good black and white picture.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 43FWX20B 43" Rear Projection...
I've got a Philips 50P8341A Projection 50'' TV. My problem started with the screen only showing an orange image. The picture was clear and sharp, but there was no color other than orange. So I tried to fix...
Turn the top left knob down till the pic comes back and the reason your color is off is the fluids in the green and blue chambers needs to be changed.
Nov 12, 2009 | Philips Televison & Video
Blue line across top of my Sony XBR 60
KDF-60XBR950 replaced bulb, but no picture. It DOES have a solid green light when on.
Jul 21, 2009 | Sony Televison & Video
Replaced bulb, picture is really dim. Same with the next replacement bulb, it's not the bulb
There are also three light imagers or optics in your set one for blue one for red and one for green could be the power supply driving them or they are bad. I had same problem with a Sony 50we610 first rear projection lcd line released most have had this issue.
Jul 01, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Z3 projector.3 years old. Blue tinge in one corner of projected picture. Grainy picture on dark scenes.
There may be some problem with your picture tube else try this that looks like retrace lines. Anyway, you should try to adjust screen pot not focus pot. Make sure you are turning blue screen pot (there are 3 focus pots and 3 screen pots) and do it slowly. If you turn it too much, it will affect your grayscale
Jun 23, 2008 | Televison & Video
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
Broke
Sounds like maybe the convergence chips are shot
Oct 06, 2007 | Zenith IQB56W10 56" Rear Projection...
Blue vertical lines - no picture
you did not mention if you have sound.but if you have sound your problem is in your video and vertical section.if no sound then you have to look into the IF section.if you are not a tech then you will have to take your set to repairman.goodluck.the tuner must not be over looked.an estimate of about $200.00 could be less.
Mar 29, 2007 | Zenith D52WLCD 52" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
64 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
