Question about Insignia NS-P501Q-10A 50 in. HD-Ready Plasma TV
My insignia plasma tv has the LED light blinking red twice, help?
  • Vernon Wells Dec 04, 2012
    I have replaced the power supply board,it looked burned out,the new one does light up a logic board,but thv insignia plasma tv will not turn ononly click twice and blink twice,help?
    Top Expert:
  • Insignia Master
  • 14,553 Answers
Hard to find parts sometimes for this brand---I would begin with the power supply by looking first at the filter caps:
my insignia plasma tv has the LED light blinking r - 12_3_2012_11_30_38_pm.jpg12_3_2012_11_30_58_pm.jpg
Posted on Dec 03, 2012
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: 26" Insignia LCD TV will not power up. Green Light Blinks 1x
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
  • 175 Answers
SOURCE: 50 inch plasma insignia no power! no red light
hi..kindly check your power supply once.
It is a common problem.
thank u..
kindly rate my response..
Posted on May 08, 2009
PhilwithDISH
  • 123 Answers
SOURCE: We just bought a NS-PDP50HD-09 Insignia 50" plasma
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang
DISH Network Customer Service Representative
Posted on Feb 20, 2011
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Not turning on led blinks twice
If your model is the TH42PZ80U 2 blinks is indicating to replace the D Board (Logic) That model used two different versions D board. www.tvcircuitboards.com has both versions and can assist with determining which version your model uses.
Feb 18, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Need the code for insignia dvd player
Hi, unfortunately there is no code for insignia dvd players with this remote. But you can do a code search and see of another code will work for it. Usually there is another code that is compatible. Try these steps below,
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then
release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its
library to the selected device, starting with the most popular code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1
through 5, but substitute the appropriate device key for the
device you are searching for.
Feb 10, 2011 | One For All URC-6011 Remote Control
Cannot program Insignia IS-TV040919 20" TV on a comcast 3 device remote (red OK button) None of the codes work.(10171,11204,11963,12002)
No problem, This issued will be only resolve with regular TV's, not LCD or PLASMA Tv's. Just press TV botton locate on the top leftside of the remote, right after hold the SETUP button for 3 seconds once the TV botton blink twice go and press 991 then 1 again, right after you have pressed 991 the TV botton will blink twice and when you press 1 will blink twice as well, after those steps keep pressing the channel up botton until your Tv shut off. That will work. Good luck
Jan 07, 2010 | Insignia Televison & Video
Code for dell plasma tv
I recommend using the auto-search function to find the codes for your Dell plasma TV.
To search for a code for your TV:
  2. Press and hold SET until the LED blinks twice, then release SET.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Nov 17, 2009 | One For All URC-3021 Remote Control
No Pictre, Flashing Power LED - Philips 42PFP5532D Plasma
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 20, 2009 | Televison & Video
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
Code for insignia tv
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
then release SET.
4. Aim the remote control at the TV and slowly alternate
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
1 through 5, but substitute the appropriate device key for
the device you are searching for.
Nov 23, 2007 | One For All URC-3021 Remote Control
Insignia ns-lcd37 remoe codes
Samsung DVD player codes: 20490, 20573, 21932, 21075, 20820.
With device turned on press DVD button on insignia remote then press and hold setup until the red led light blinks twice. enter code and it should blink twice again. press power button to check if code took. If not, try another code.
Oct 29, 2007 | Televison & Video
Insignia NS-P501Q-10A 50 in. HD-Ready Plasma TV Logo
424 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
