How do fix Hp compaq d530 ''NTDLR missing''
  • Computers & ... Master
  • 27,725 Answers
First make sure there are no disks in any of the drives cd floppy and usb Computer is booting from a non-bootable source.
Computer hard disk drive is not properly setup in BIOS.
Corrupt NTLDR and NTDETECT.COM file.
Misconfiguration with the boot.ini file. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32
New hard disk drive being added. Corrupt boot sector / master boot record.
Seriously corrupted version of Windows 2000 or Windows XP.
Loose or Faulty IDE/EIDE hard disk drive cable
Failing to enable USB keyboard support in the BIOS.
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CDROM First verify that no FLOPPY DISKS or CD is in the computer, unless you are attempting to boot from a diskette
Test all power and data leads that attach to your hard drive including IDE,SATA
if ita flat 40 pin ribbon type it will be the first to fail.
The leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty
Make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
Computers need power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
also
When NTLDR is missing from your operating system it means that there is a problem with your boot loader, a bootstrap process that begins when you turn on the computer.
A missing NTLDR means that your computer cannot boot to the operating system.
This issue is only a problem on computers running Windows XP or previous operating systems as Windows 7 and Vista don't utilize NTLDR.
Fixing the missing NTLDR is relatively easy so long as you have your installation disc.
Locate your Windows XP/2000 installation disc and place it in your CD/DVD ROM drive. If you don't have this disk, then you cannot proceed further.
Restart your computer.
When the computer restarts press any key on your keyboard when you are prompted, "Press any key to enter setup."
Most computers are configured to boot to another device other than a hard drive.
Since the Windows XP/2000 installation disk is bootable, you should see the prompt.
However, if you don't see the prompt you may need to change your boot priority in your BIOS. To do so, enter the system BIOS by following the onscreen instructions upon startup.
Then navigate to the Boot Priority menu and modify another device, such as a CD-ROM to boot prior to the hard drive.
Then reboot your computer.
After you have pressed any key, the Windows XP/2000 setup screen will appear.
After loading, press the "R" key to repair the Windows installation.
The screen will appear black.
The computer requests which installation you would like to log in. Generally speaking, press "1" and "Enter."
If you have more than one hard drive or more than one partition, the procedure may be different.
You must know which hard drive or partition your Windows operating system is installed in.
You are subsequently prompted for a password.
If you haven't set up one up, you can just leave the query blank and press "Enter."
The phrase "c:\WINDOWS>" and a blinking cursor subsequently appear.
Type "copy d:\i386\ntldr c:\windows" (without quotes), where "D" is the letter of your CD/DVD ROM drive (your optical drive may be different, especially if you have more than one).
Eject the CD from the drive and type "Exit" (without quotes) to restart your computer.
The NTLDR file will be copied from the installation disc to your hard drive.
or
If you've started your Windows XP computer and you see an error message to the effect that the "NTLDR" file is missing or corrupted, you've probably also noticed that the computer refuses to boot any further.
This is because the NTLDR file is an integral part of the boot process and needs to be restored before the boot process can proceed normally.
Insert your Windows XP disc into your computer.
Restart the computer and press any key on your keyboard when the message prompting you to do so appears.
Press the "R" key to open the Recovery Console and then press "1" and "Enter" in order to select your operating system.
Type in your Administrator password (if needed) and press "Enter."
Type "copy d:\i386\ntldr c:\" and press "Enter" and then type "copy d:\i386\ntdetect.com c:\" and press "Enter."
Restart your computer and let it boot up normally.
Since the NTLDR is freshly restored, the computer boots up properly.
Hope this helps.
Posted on Dec 03, 2012
  • 8 Answers
SOURCE: hp compaq driver d530 sff
I found the drivers I needed at http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
I am running XP and used SoundMax Integrated Digital Audio for audio &
Intel Graphics Driver for Microsoft Windows 2000/XP for video.
Posted on Aug 19, 2008
Beni S-P
  • 1006 Answers
SOURCE: 5 beeps HP Compaq d530
5 Beeps
CPU or motherboard problem
Posted on Apr 11, 2008
mdsaeed67
  • 849 Answers
SOURCE: Full Restore of Window XP of HP Compaq D530
u need to use system recovery cd supplied with system. if u dont have, create the same from your computer from recovery partition.
Posted on Nov 27, 2008
buffalonyman
  • 1865 Answers
SOURCE: ethernet driver for hp compaq d530
Drivers are located here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
You must select the appropriate operating system for your application
Posted on Apr 25, 2009
  • 156 Answers
SOURCE: Ineed hp compaq d530 driver
The driver is available on the HP website. I believe it's a broadbent The PCI SFF modem should be easy to come by. Try this link:
http://www.pcliquidations.com/item.asp?id=3694&referid=160164167166161
$20 bucks.
Your ethernet board is a Broadcom. Here's the link and just select your operating system:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=316715&prodTypeId=12454&prodSeriesId=316713&swLang=13&taskId=135&swEnvOID=1093#11395
Hopefully the entire link will work...but if you go to hp.com, go to the support section and type in your model number and you'll find it.
Posted on Jun 04, 2009
1801-Unicode update error. Missing or invalid processor microcode update."
To remove this error, you have to download and install the following
HP COMPAQ D530 SFF Microcode Update
Download the update from the above link. Read / follow the instructions carefully.
This package contains a utility that can be used to install or upgrade the processor microcode on the listed HP Compaq Business Desktop D530.
Hope it helps! Good Luck!
CreativeTECH
Oct 05, 2011 | HP Compaq d530 SFF PC Desktop
My HP Compaq d530 SFF has more than 1.7gb of RAM. It has 2.40gb processor but i can't install windows 7. i don't know why?
Probably not compatible with Win7. Check HP's web site for that model. You might find out what operating systems are supported.
Sep 24, 2011 | HP Compaq d530 SFF PC Desktop
I WANT TO DOWNLOAD HP COMPAQ D530 CMT
you can easily download the setup from the following sites
forums11.itrc.hp.com/service/forums/questionanswer.do?threadId
h18000.www1.hp.com/products/quickspecs/11632.../1163
h30499.www3.hp.com/t5/...PCs...HP-d530-CM
ptf.com/vga/vga+hp+compaq+d530+cmt
www.topshareware.com/...hp-compaq-d530-cmt.../downloads
www.user-guides.co.uk/download/hp/hpcompaq/hp-compaq-d530-cmt-manual-placa-
download and install it on your device,it will work just be fine
Jan 14, 2011 | HP Compaq d530 CMT PC Desktop
Hp compaq d530 CMT motherboard diagram
You are missing the front headphone / microphone connector that plugs into the motherboard. Or a way to jump this to close the headphones so the sound will come out the back.
Aug 03, 2008 | HP Compaq d530 SFF PC Desktop
5 Beeps
Apr 11, 2008 | HP Compaq Business d530 Ultra-Slim PC...
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
