Question about Minolta CF2001 Copier
After change the oil coating unit the screen still appear change oil unit soon
  • Minolta Master
  • 1,294 Answers
Cear the consumabile parts life counter.
Posted on Jan 29, 2013
How do I reset the computer after changing the oil myself ? The change oil light comes on for about 30 seconds before going out. The motor is a 4.9L. Thank you...
Depress and hold RANGE and FUEL USED buttons until OIL LIFE INDEX appears on DIC display. Depress and hold RANGE and RESET buttons for 5-60 seconds. When OIL CHANGE SOON light flashes 4 times remaining oil life index is reset to 100 percent. If OIL CHANGE SOON comes on and stays on for 5 seconds, display did not reset, and you will have to try again.
Mar 07, 2011 | 1993 Cadillac DeVille
Tip
Pontiac service light 1983-01
Firebird
1998-01
To reset the "CHANGE OIL" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and goes out, the system is reset.
Grand Am
1999 -01
To reset the Change Oil light, open the driver's side instrument fuse panel and turn the ignition on. Press the "RESET" button and release. The light will flash. Press the button again and the system will be reset.
Grand Prix
1999-01
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Grand Prix
1997-98
To reset the oil life indicator, press the "MODE" button until the light next to "OIL LIFE" is lit. Press and hold "RESET" for 3 seconds until oil life percentage is 100%.
Grand Prix SE
1997
Turn the ignition on, but do not start the vehicle. Within 5 seconds, push the accelerator to the floor 3 times. Turn the ignition off. Start the car and the Change Oil Soon indicator light will be reset.
Grand Prix
w/ Trip Computer
1988-93
To reset "CHANGE OIL", "CHANGE OIL FILTER", or the mileage of either on the Trip Compute, continually press the "SERVICE" or "SYSTEMS CHECK" button until the item appears with the mileage below it. Then press the "RESET" button and the mileage will be reset to the maximum value. If you want to reduce this value, hold the "RESET" button down and the mileage will count down. Release the button at the mileage you would like to observe.
Bonneville,
6000
w/ Driver Information Center
1983-91
To reset "CHANGE OIL SOON" or "OIL FILTER" or to adjust the mileage on the Driver Information Center, continually press the "DIC" button until either message appears with the mileage below it. At this point, hold down the button. In 5 to 10 seconds, the mileage will count down. When it passes 0, it will cycle back to a maximum figure. Release the button when the mileage gets to the service interval you'd like to observe. If "CHANGE OIL" or "OIL FILTER" already appears, just hold the button down to reset the mileage. "CHANGE OIL" and "OIL FILTER" are reset separately.
on Dec 07, 2009 | Pontiac Grand Prix Cars & Trucks
How do you reset the change oil soon display on a 2008 yukon after changing the oil? how many quarts does it take?
Hi. You have these 4 buttons in a row (DIC buttons) you can find it near the left of the center a/c vent.. Select the button with the car icon. Press on this button repeatedly until the "% OIL Life Remaining" appears on the IPC messages screen. Stop there. Press and hold that same button until the message indicate "100% Oil Life Remaining". With a new oil filter, around 5.6 liters. And that's it. Okay, sir? : )
Jan 04, 2011 | 2008 GMC Yukon
How do I reset the change oil light after changing the oil. It did not go out.
Try this and if it does not work let me know.
1. Turn the ignition key to the "ON" position without starting the engine.
2. Fully press and release the accelerator pedal three times within five seconds.
3. If the CHANGE OIL SOON indicator flashes two times, or the display reads "OIL LIFE INDEX RESETTING 100%" then the system is resetting.
4. Turn the ignition key to "OFF", and then start the vehicle.
5. If the CHANGE OIL SOON indicator comes on and stays on, or CHANGE OIL SOON is displayed then the system did not reset and repeat the procedure.
1. To reset the OIL LIFE indictor if equipped with a Trip Computer, press the TRIP MODE button until the light appears next to OIL LIFE.
2. Press and hold the trip RESET button until the oil life percentage changes to 99%.
Sep 14, 2010 | 2001 Pontiac Grand Am SE
Oily coating inside of windshield
Coolant will be orange or green in color
Freon evaporates although if an AC leak a slick oil can appear
Jul 31, 2010 | 1994 GMC Sierra
How to reset oil life ,on the computer
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the DIC, (Driver Information Center) press the "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (usually after about 5 seconds).
Jul 14, 2010 | 1990 Cadillac Eldorado
Sevice engine soon sign, what to do? Already changed the oil but the sign on the dash board is still on.
Turn the ignition key to the on postion (but do not start the vehicle) .Then push the trip odometer button a few times until the word oil appears on the screen. There will be a number next to the word oil. Hold the button in until the number 100 appears next to the word oil and then your good to go. Good luck and this should work.
Jul 12, 2009 | 2004 Chevrolet Venture Passanger
I have a pontiac g6 and my change oil light has been on. i went and got a oil change and nothing happened and i cant see where to put the tRANSNISSION FLUID??
With the "CHANGE OIL SOON" message displayed, press any of the three DIC buttons to clear the "CHANGE OIL SOON" message. Display "OIL LIFE RESET" on the DIC. Press and hold the "ENTER" button for at least one second. An "ACKNOWLEDGED" display message will appear for three seconds or until the next button is pressed. This will tell you the system has been reset. Turn the ignition to "OFF". If the "CHANGE OIL SOON" message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the procedure. on the 3.5 liter you have a dipstick near fire wall
Jun 13, 2009 | 2006 Pontiac G6
Oil service reset
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center;
  1. Press "ENG-DATA" button until the "OIL LIFE INDEX" appears.
  2. Press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
This is what I found on your car bud. I hope that's what you're looking for. :)
Sep 21, 2008 | 1989 Cadillac Eldorado
Change Oil Soon light won't go off even after changing the oil.
You are able to reset it. The directions are in your manual:
1. press the options button under the screen utnil ENGINE OIL MONITOR appears on the DIC screen
2. Press the set/reset button to reset the system
The next screen indicates that the engine oil monitor system has been reset.
If the message is still on...try steps again
Jul 16, 2008 | 2006 Pontiac Grand Prix
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
