Question about Texas Instruments TI-30XA Calculator
6+3racical 2 how would I type in this problem to find the approximate solution
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
If you mean 6 plus cube root of 2 then press
6 + 2 2nd [cube-root] =
The cube root is the shifted function of the 0 key.
Posted on Dec 03, 2012
Waterheater does not keep water hot when you get in the shower first thing in the morning you have to turn on only the hot water or the water is cold
1) Unknown water heater type, brand and model.
Check for crossover first to eliminate plumbing problem.
http://waterheatertimer.org/Crossover.html
2) Add comment with more information about water heater for possible assistance, and give type, approximate age etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 21, 2013 | Water Heaters
Loud squeaking on my Reebok 9500 ES (three years old) from under the hood when the foot hits the treadmills - at various speeds and inclines.
HI,
Its time to lubricate your treadmill.
You must obtain the proper lubricant for your treadmill. There are several different types. Contact your manufacturer for what type is needed. Using the manufacturer provided allen wrench, loosen the walking belt approximately 10 full turns on each side of the rear roller. Apply approximately 1/2 ounce of lubricant directly in the middle of the walk area underneath the walking belt upon the deck. Retighten the rear roller 10 turns on each side. Run the treadmill at 6.0 mph for 2-3 minutes to spread the lubricant evenly. Wipe excess lube from the sides of the belt. Walk on treadmill to check for proper tension on belt.
for make it easy for you I have added a video. ok
Aug 27, 2011 | Reebok Exercise & Fitness
I have a ET-388 threadmill. however when i walk or run on the machine the sound is very heavy. can you tell me what is wrong of is it normal?
hi,
Jul 14, 2011 | Spirit Esprit by ET-8 Folding Treadmill
Oil change .... amount and type 2425N
I recommend type 30 all season full synthetic. Approximately 2 quarts. Full to the bottom of the fill plug threads.
Oct 30, 2010 | Ingersoll Rand Electric Driven Two Stage...
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
Remote start issues with 93 acura legend l base 4 door
Generally there are two types of factory ignition key security types one creates a circuit when you put and turn the key(these generally have a chrome nipple on them which creates the contact)and the other type is an approximity type(most common)if its the approximity type you can test this by trying to start the car(with the remote) and hold the ignition  key as close to the ignition barrel as possible, if this works let me know and i;ll pass on the next step.If not you may need a bypass module.please provide more details about the car and the alarm.(model etc)
Apr 20, 2009 | Vehicle Parts & Accessories
TV will not come on andthe red power light starts blinking in a short series of 6 blinks and a pause of approximately 2 or 3 seconds.
its haveing a power problom. it had a power serge thats why it dose that. i work on them everyday it has a bad power chip. if u want to get rid of it email me at moonlight1874@aol.com
Sep 27, 2008 | Panasonic TC-32LX60 32 in. LCD Television
Service Code
The maintenance service indicator shows the maintenance service type (letters A-H) in the multifunction display. This service type is only to give the customer an approximate time required to perform the required maintenance ranging from approximately one hour for Service A to approximately eight hours for Service H.
To determine the actual service items required, you must call up the service item menu in the multifunction display. Refer to instruction below.
Calling up the maintenance service data information
The maintenance service indicator shows the maintenance service type (letters A-H) in the multifunction display approximately one month before the service appointment is due in miles (distance criterion) or in days (time criterion).
This maintenance service type is based on the service items to be carried out. The service items are described in the Maintenance Booklet.
The service items to be carried out under the corresponding service type can be displayed in the multifunction display example Service "D" on my 2005 E320 4MATIC at 12,000 miles.
PK112101-M.............112 LUBE MOBIL........*****
007603-014106........RING, GENERAL..........$1.58
000-180-26-09.........OIL FILTER F...............$22.71
001-986-80-71-10....WINDSHIELD W..........$3.44
M0-40...................... MOBIL-1BULK(QTY8)...$47.92
BG110.......................ADVANCED MOA..........$10.95
BG203.......................FUEL TREATMENT........$11.95
SOLV.........................W/W SOLVENT............$2.25
TOTAL PARTS $100.80
TOTAL LABOR $317.95
SHOP SUPPLIES/HAZARDOUS DISPOSAL $47.69
TAX $5.04
GRAND TOTAL $471.98
May 24, 2008 | Mercedes-Benz E320 Cars & Trucks
Ti-89 titanium SIN!!!!!
The answer that you have received in actuality is correct. However, it is in exact form when the answer that you were looking for was an approximation (decimal form) answer. To achieve this all you have to do is hit the alpha button (the yellow button with a diamond in the center) and then enter which will give you your desired answer :-)
Jan 14, 2008 | Texas Instruments TI-89 Calculator
TI-89 Problems
There isn't anything "wrong" with it.
Go to mode, and set the results of your inquiries from Exact to approx.
If you put in cos(e^2), it will print out cos(e^2) because it's the most exact it can be without going into a decimal. (cos(e^2) will be a transcendental number like Pi).
Sep 09, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-30XA Calculator Logo
50 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
