Question about Dishwashers
MAYTAG MD85600AWS NOT DRAINING - Dishwashers
Maytag top washer not draining
You will need to replace the drain pump. What is the model number?
Aug 13, 2012 | Maytag Washing Machines
HAV2360 Maytag does not drain before spinning. Drain cycle seems not to engage.
Unlike Whirlpol and Kenmore washers Maytag Washers drain and spin at the same time.
Apr 10, 2011 | Maytag HAV3460AWW Top Load Washer
My tub won't drain correctly, we followed the maual and still not draining fully from tub. I have a maytag front loader.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 15, 2010 | Maytag Washing Machines
Maytag atlantis washer not draining
you say it does not drain...do you hear a humming? or is it dead? if it's dead you probably have a problem with your lid switch
Jun 01, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAH8700AWW - detergent drawer full of water
try removing the drawer to see if one of your kids has put something in there
Dec 13, 2009 | Washing Machines
Top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Jul 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
Maytag legacy series washer not holding water
Same problem here. But according to Maytag Service, the draining pipe may be too deep inside the draining tube on the wall, thus creating a siphon effect and not allowing the tub to fill.
Their suggestion is to ckeck the pipe and make sure no more than 6-8 inches are inside the draining pipe. This should take care of the suction. We'll see, Imma do that when I get home.
Jan 06, 2009 | Maytag Legacy Series Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
