CAN AND CAN'T CONNECT IMATION TO MY PC!My laptop does not detect my Imation Grand Entertainer HDD Multimedia Player when I connect it to the USB portal. I took it and my laptop back to the shop a
  • Mick Shaw Jul 22, 2013
    I also have the same exact problem, I have been back to the shop twice and both times it has worked. Still cant get it to work on laptop at home. Have you had any answers to the problem ?
  • r_siva33 Apr 20, 2014
    hey jz connect usb n power supply only don't connect like hdmi all other outputs it will help u
This problem is caused by hard drive only. your hard disk is not working properly so open the cover and remove circuit board then you can see the hard disk attached with circuit board .please remove the HDD and connect if you have spare HDD(2.5 inch HDD also you can use) please connect and see it will work.my grand entertainer is working with 2.5 sata HDD now
Posted on Oct 13, 2013
Gort007
  • 1187 Answers
SOURCE: my new portable hdd is not getting detected on my xp
Your USB ports may be version 1.1
You need a USB "Y" cable.
The USB Y cable uses two USB ports on your laptop and the third plugs into the external HDD.
Check RadioShack or maybe the vendor has a USB Y cable.
This will work!
Posted on Sep 08, 2009
linswad
  • 258 Answers
SOURCE: My imation USB Hard Drive once i connect to USB
Sounds like it's not getting enough power from the USB port on the laptop. Drives like this usually have a 2nd USB connector for more power from a 2nd port. If you don't have a free port, you can buy a powered hub and use that for the drive. It has its own power adaptor so will provide enough power for the drive when both drive connectors are plugged in.
Posted on May 31, 2010
Crankstart
  • 696 Answers
SOURCE: Solve Your "Imation Odyssey HDD Cartridge
Do you have more than one of the cartridge drives?
If you do, a simple test is try another drive, if they both failed to respond in a similar fashion the bay has issues and may need to be replaced. If the other drive works properly in the bay that cartridge or drive inside is likely the problem and will need to be sent for data recovery if you need the files back or just scrapped for a new unit if there's nothing crucial on it.
If you require data recovery, comment back with your Country, State and City and I will be happy to recommend a nearby facility that can help you out.
Chris
Posted on Aug 30, 2009
  • 45 Answers
SOURCE: i have an Argosy Mobile
Hello.
for this problem a simple solution is here change your Harddrive USB Cable and check it its working or if its not working please check in under device manager remove USB Driver and Install it again
Posted on May 15, 2011
  • 149 Answers
SOURCE: Imation Apollo UX The small LED indicator that
I will advice to buy another one
Posted on Sep 27, 2011
Imation HDD Pro Media player 500 gb. orange light flashing but not detected by my laptop.
You "killed" it -- either the USB-to-disk-drive adapter inside the case, or the disk-drive inside the case.
Remove the disk-drive from the case, and install it in a replacement case (with replacement power-supply).
May 09, 2015 | Imation Computers & Internet
Imation 11795 driver WindowsXP
IMATION stopped making the "LS-120" (Laser Servo) drive many years ago, when USB-interface memory-sticks became cheaper & faster. Imation did have parallel-port device-driver software for Windows 95/98/ME, but never updated them for Windows NT/2000/XP.
Instead, disassemble the case, and you will find an IDE-interface Imation LS-120 drive inside. Connect the same "smaller" 4-pin power-connector that used to connect to a 1.44 Mbyte 3.5-inch diskette, set the "master/slave" jumper, and connect an 80-pin IDE ribbon-cable, and connect the other end of the ribbon-cable to an IDE socket on the motherboard.
Jul 06, 2014 | Imation Superdisk Drive 120mb Parallel...
Imation usb cant read
Try connecting it to a different computer, preferably running Windows 8.1 -- if it still is not detected, it is "dead".
Feb 20, 2014 | Imation 16GB USB Flash Drive 27125
Imation apollo 2.5 portable HDD 250 GB driver missing?
Just download it from Imation.com. Install it and your on your way.
Feb 16, 2014 | Imation Apollo (27223) 250 GB USB Hard...
Imation 250 12.5m U3 in my laptop but cant open
Connect it to a different computer.
If no success, it is "dead".
Oct 24, 2013 | Imation Apollo UX 2.5" USB Portable (250...
Flashing light micro
try all USB ports on PC
try different PC or labtop.
never use USB external hub for HDD.
if still dead, its , dead.
they have a support site, use that.
http://www.imation.com/en-US/Consumer-Products/Consumer-Products/External-Hard-Disk-Drives/
Sep 29, 2013 | Imation Apollo (27223) 250 GB USB Hard...
Hi, Brand : Imation Model : Apollo M250 Capacity
Hi, The hard drive Apollo M250 does not have any locking mechanism. It only has backup software. If your computer does not detect the HDD, it only means that the HDD is already broken.
Aug 15, 2011 | Computers & Internet
Hello there. I can't view the files on my Imation Apollo M100 2.5 Portable HDD. I was able to use a few days back, copied and transferred some files to and from my netbook. But now, I couldn't...
change the usb and then check else if its working or not..check also if its working on any other computer..if its not even detectable at other computer as well then the hdd itself must be the faulty..contact the manufacturer
Aug 10, 2011 | Imation Apollo UX 2.5" USB Portable (250...
My emation apollo 250 usb HDD is not opening. I need to format that disk. Please help
Restart your pc whilst the usb disk is connected. After the restart, right-click on the USB disk in ''my computer'' window and select ''format'' from the drop down list. Just click format to get your disk formatted after you are prompted ''format complete'' Hope u are true now.
Jun 08, 2011 | Imation Apollo (27223) 250 GB USB Hard...
Hi.My Imation Apollo 2.5" 500GB
With any luck, it may just be due to a loose cable or connection inside. You need to open the unit and make sure everything is properly connected.
Mar 14, 2011 | Imation Apollo UX 2.5" USB Portable (250...
Computers & Internet Logo
1,068 people viewed this question
David Payne
David Payne
