My tv is showing plaid and I don't know why. It's refurbished. Help please anyone
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Main board most likely-processes all signal to the screen among other things---refurbished sets are in my view are no bargain--they do as little as possible to get it out the door---years ago when I worked for Circuit City a very high percentage of failed sets were repaired/refurbished ones---buying someone else's lemons.
Most also come with a much shorter warranty as they really do not want to stand behind them very long.
Posted on Dec 03, 2012
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Need free repair instructions-manual- for 46
no manuels are necessary the new panel will come with logic and ballast board already you only need to transfer main and power supply .
Jun 09, 2010 | Samsung 46 in. LCD HDTV
The picture on my LTV-19w3 WH tv just shows a blue, black, or green screen with about a 4" sq. plaid patch in the upper right hand corner. Sometimes the sounds works other times it does not. Can anyone...
While the TV is on do the following:
1. Press the "Right Arrow" button on the remote.
2. Press the "Left Arrow" button on the remote
3. press the number keys in order, 1-9
I believe you are in the TV's service menu and the Blue/Green/Black are just test patters. If so, pressing these keys will eventually change the pattern..
Get to the main page of the service menu and press the [power] button on the remote.
Jun 16, 2009 | Westinghouse LTV-19W3 19 in. LCD...
Green Plaid Screen
Are you able to access the on-screen menus (like brightness/contrast etc)?
If those menus are appearing over the green screen, then it might be a cable or image source problem. I've often seen this green screen when the HDMI encryption between my cable box and my TV gets messed up. Only solution has been to power cycle the cable box.
If you can use something other than an HDMI cable to connect your TV to your picture source, I suggest trying that and seeing if you can get SD channels again. If you do get them back, it was a cable issue. If you still can't get them, contact your cable/satellite provider, see if there's something up with their signal.
May 30, 2009 | Samsung HLP5067W Television
Green Plaid then Vertical Lines, Failure of hard controls, Analog Board?
You are absolutely correct, When anyone complains of vertical lines or bars, the next step is to see if it happens on only digital inputs ( digital board ) , only analog inputs ( analog board ) , or both ( DMD board ) .
Analog board can be purchased at www.partstore.com ,
Jun 04, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Green Plaid Screen
I think what you are describing is a form of line paring which is caused by a defective IC in the video circuit those inputs are feeding. Post a email link ad I will send a pic of a screen that has this problem and you can let me know if thats what your experiencing.
Jan 27, 2008 | Samsung HLP5067W Television
Magnavox 37" LCD HD TV 3 years old
You may need to replace the Small Signal Board of your tv.
Nov 25, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
PG-C30XU projecting criss-cross plaid image.
i suggest you do not have the projector too far away... 7ft away distance would be a Good resolution will also dimm don the square's image in the picture
Nov 08, 2007 | Sharp Notevision PG-C30XU Multimedia...
Horizontal Plaid Lines throughout the picture
You mentioned the Magnet possibility, check around its location or move it to another site. Check also cabling where it runs and connections swap USB connectors or even if you have other USB stuff running that you could do with out. Its all a process of elimination before you have to decide to bin it.
May 14, 2007 | Logitech ClickSmart 310 Digital Camera
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
