Question about Sony KP-57HW40 57" Rear Projection Television
Sony KP 57HW40, blue flashes and sometimes shuts off
I figured out how to get rid of the red or green archs thanks to FixYa a year ago. Small adjustments to the screws does it. I was a EE so not dumb. Now it gives me periodic "blue flashes" on the screen. Whole screen blue for an instant. Sometimes it shuts itself off. Now comes the question, since it must go in for repair and repair is expense I am guessing since it may be a board or a part, is it really worth fixing?
  • 1 more comment
  • Anonymous Jan 20, 2009
    blue flashes tv shuts off then the standby light flashes eight times in a row
  • sweetierook Jan 27, 2009
    green arch lines screen turns blue flashes turns itself off
  • cowboy92684 Jan 29, 2009
    what screws did you adjust to fix the lines? also i have the same problems witht the blue flashes and also some red flashes and it turns it self off alot then it stops for a week and then it does it again can anyone help?
  • 905 Answers
Can you solder? there may just be some dry solder joints and or caps and a voltage regulator that are causing this.
otherwise you are looking at a $400 or so repair!
Posted on Jan 11, 2009
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Sony Color Rear Video Projector - KP 57hw40 / Mfg. February 2002
i have the same problem picture is blue/green with blue and green arched horizontal lines
no picture at all only sound then tv shuts off after 5-10 seconds and then a bright blue flash in the center of the screen
have tried adjusting the voltage screws didnt do anything
Jul 13, 2008 | Sony KP-57HW40 57" Rear Projection...
A few green flashes and the TV shuts down, blinking stand by light.
If you get rid of your TV I will buy your blue Tube Mike Audiomonkey@comcast.net
Mar 22, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Kp-57hw40 screen goes bright red or green then powers off
http://esupport.sony.com/perl/news-item.pl?news_id=24
heres a recall of sony hope it helps.
Dec 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
Probable bad blue CRT and if blue goes bad guess what might
happen to the red and green.........T.
Nov 07, 2007 | Sony KP-46WT500 46" Rear Projection...
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
SONY KP57WV600-Turns Blue
yes ,it sounds like screen adjustment or focus block, should be around $200- $325 to repair.
Sep 08, 2007 | Sony KP-57HW40 57" Rear Projection...
Green flashes
It is a defective green CRT and most likely the red and blue will need to be replaced as well. This was a known issues with this year of Sony projection TV's.
Apr 07, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
93 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
