Question about Dell Inspiron Mini 10 N450
How do i install memory - Dell Inspiron Mini 10 N450
  • 14,384 Answers
USE GOOGLE CHROME.
Posted on Dec 04, 2012
Applications not installing in memorycard nokia 5230
try to update your software of your mobile.
Feb 10, 2012 | Nokia 5230 Cell Phone
Tip
How to install high memory games and software to samsung gt starting series...
Have you ever wondered how to install high memory games and software to your samsung mobiles!<br />well, its time to get rid out of your long wait to play those awesome high memory games and to install that 2 m.b. Oxford dictionary:-)<br />you just have to press *#52828378# to your standby screen of samsung mobile. And go to "OTA MEMORY SETTING" and increase your java heap size memory to as high as your memory requirmenu of your software.<br />ex:- if you want to install a game of 650kb then increase java heap memory to 650kb, and yes you can now install them from the memory card and can play them if they support your mobile.<br />well before installing any game look your application internal memory should be blank to the level you want to install.<br />best of luck, happy gaming!<br /> <br />regards!
on Jul 20, 2011 | Cell Phones
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
I installed two new 1 gigabyte memory sticks into a Dell Inspiron 6000, which previously only had 2 256 megabyte memory sticks installed. When I first installed the 2 gigs of new memory, the laptop turned...
Once you installed the memory, did you enter into the System BIOS Setup screen? Do this and verify that the system recognizes the newly installed 2GB RAM. This should let the system access the new memory once you boot.
Jan 01, 2011 | Dell Inspiron 6000 Notebook
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
What is the maximum memory I can install
Memory Upgrade for Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop, the Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop takes the Memory Type, and comes installed with 0MB of Memory. You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory, already with 0MB standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Jul 08, 2010 | Acer Aspire 5630 Notebook
Help my pc is not detecting the correct amount of ram installed
Okay, first things first. IF the memory you installed is 1024 and you are using the on board video and it is 512 MB, you will only have 512 MB usable memory. This is because the on board video uses the installed memory to function. What ever the video memory is, subtract that form the total memory. If this is not the case, try re-seating the memory. If the numbers still do not add up then if there are four memory slots, make sure the memory is installed in the same color slots. Most desktops with 4 memory slots have two slots one color and the other two another color. Make sure both memory sticks are installed in the same color.
Jan 06, 2010 | Computers & Internet
I have htc 3400i but cannot install games
you are referring to the external memory(Storage card), but the phone requires phone memory to install
any application. Somehow by installing many applications or storing data in phone memory or cache memory that grows with browsing, your phone memory must have very less space and so it's saying no memory. Please free up by deleting unnecessary space and try installing it.
Jan 01, 2009 | HTC Touch P3452 Smartphone
Installing Memory
Hi
Yes, you can replace/upgrate the memory module under the keyboard.
Before you proceed, note that Dell Inspiron 2650 uses DDR200 3.3V SODIMM modules. Also, memory module capacities supported are 128MB and 256MB with a Maximum memory of 512MB. If the current memory installed is 128MB, you need to order 2x 256MB modules to replace/upgrade both memory slots. If the installed capacity is 256MB, you just need another 256MB for the slot underneath the laptop.
Check "Removing the Keyboard" for guide removing the keyboard to access the 2nd memory slot.
Read "Preparing to Work Inside the Computer" before committing to the above procedure.
Let me know how you get on.
Mike
May 24, 2008 | Dell Inspiron 2650 Notebook
Dell Inspiron Mini 10 N450 Logo
19 people viewed this question
Alun Cox
