Question about Pool & Spa
I have a 7yr old thermo spa Atlantis with one pump the pump wont shut down as I understand it should only run about 4 min. every 30 min. to check the temp. the temp is holding at 104 degrees. whats th
I have shut down the breaker When I turn it back on The panel reads PR which I understand is Prime which is normal. but then the pump kicks in and wont dosent shut down. The pump will kick into high and everything eles seems to work normally
  • 61 Answers
SOURCE: My teledyne Laars Telstar Model TGS-50 spa heater
Without doing more troubleshooting i would have to say that it is the main board (the board with the knobs on it) Take it out and see if there is any corrosion on it.
Posted on Apr 06, 2009
  • 83 Answers
SOURCE: Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Posted on Jul 10, 2009
  • 5 Answers
SOURCE: Pential Easy Touch Pool/Spa remote says the water
you can change the calibration on the temp. or how did you check the sensor
Posted on Oct 05, 2009
  • 990 Answers
SOURCE: E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Posted on Dec 03, 2009
  • 990 Answers
SOURCE: Ref: Sta-Rite Max-E 400. Pool temp is about 75
Your temp sensor has gone bad and will need to be replaced. It's a small tube that slides into the water manifold and you can follow the wires back to the board. Just unplug and set a new one in place.
Posted on May 13, 2010
Overheats, shuts down and later on again
need more info is it a pump that does that? is so the thermos are shutting it off you need a new pump or pump motor or check to see if power leads to motor and breaker are tight make sure to do when power is off
Aug 31, 2014 | Pool & Spa
Tripping circuit breaker
Hi Kathy
Sometimes when a breaker keeps tripping, it will wear and will be in need of replacement...try replacing the breaker and see if that solves your problem.
If not then check the amps on the pump and make sure the breaker is able to hand the amperage the pump is requiring.
Bud
Oct 09, 2013 | Pool & Spa
Why is the gfci tripping on my hot tub after being on for 30 min. After resetting the breaker after the 30 min. run, it trips immediately!!!
You will want to make sure that all of your spa equipment is functioning properly. It is best for a spa technician or electrician to determine this issue.
It is likely that a particular piece of equipment is turning on around the 30 min time frame and causing the breaker to trip. Pump, ozonator or similar. Also check the heater element, a pin sized hole in the element will cause it to fail. Lastly your spas breaker itself could be bad.
Nov 20, 2012 | Pool & Spa
I am using an AO Smith motor on a Hayward pump to run my pond. It is about 4 years old now. Most recently, in the hot weather (90+F in the Northeast) the pump just shut off as I was watching the...
pump is protected with a thermo switch made inside the motor to shut it off if it gets to hot check for oil ports at the bearings if it dose not have them maybe try adding a ball valve and turning down the flow some to create slower flow and higher pressure
Aug 31, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Pool & Spa Logo
53 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
