Question about Savin Office Equipment & Supplies
Savin 9922dp/3222 error code sc544 - Savin Office Equipment & Supplies
Matt_Sr
  • 31 Answers
SOURCE: I have a Savin 9922DP red wrench and code SC 546
Parts availability ended for this machine Jan of 07, now is a good time just to chuck it.
Posted on Jun 19, 2009
savindude
  • 175 Answers
SOURCE: resetting the photoconductor unit
After replacing the PCU, you can clear the counter by going to Clear mode, 107, push and hold Clear/stop. Screen should change. Push Copier, 7804 should clear drum counter.
Posted on Jun 29, 2009
SOURCE: SC544 functional problems ERROR CODE ON REX ROTARY 1808D COPIER
fuser problem. Call for service
Posted on Jul 26, 2009
SOURCE: MY SAVIN 9922DP does not copy
It can be lacking develop in the image unit or damage the gear that drive the Mixing Paddle Roller.
It is generally necessary to change the image unit.
Posted on Sep 17, 2009
  • 46 Answers
SOURCE: service code sc544
It is a fuser overheat error....really has to be checked by a technician...
note that any Ricoh tech can also do it as it is a Ricoh machine
Posted on Nov 06, 2009
How do I reset fuser code on savin 2513 with a sc544. I have checked the fuser lamp thermal fuses etc. From the power source in cable unplugged. The thermistor reads about 390 k ohms at room temp. It had a...
When reading the thermistor, grasp the sensing part between thumb and forefinger, if reading drops quickly the thermistor is probably goid, if so , unfortunately you may need a power supply board
Feb 12, 2015 | Savin Office Equipment & Supplies
Savin 8045 sc544
error 544 is associated with the fuser, call aechnician to change the thermisters and thermofuse of the fuser and the problem is solved
goodluck
Feb 05, 2014 | Gestetner Office Equipment & Supplies
Trying to replace toner in a savin 9922dp. install the toner cartridge, copier runs like it is loading the toner but then the error message to replace toner appears again (over and over)
take the toner out - whilst the green handle is up (this will get your hands dirty) feel inside for a left over cap from a previous toner. remove it and put your new toner in. this should sort it
Oct 02, 2013 | Savin 9922DP Toner 6 Ctgs/Ctn 66000 Yield...
With no error codes being displayed, this could be any number of things. The easiest to try is a new type 270 PCU. The cover over the laser write unit could be completely covered with toner (not likely). The transfer roller doesn't have any voltage going to it. That is the long black rubber (like) roller you see when you open the right side door. Check to make sure the contacts to the roller are all good and clean.
Anything else I can think of should give you an "SC" code.
Sep 15, 2009 | Ricoh Aficio 450 Copier
Resetting the photoconductor unit
You need to enter service mode and the # is SP 5-912-1 set this to 0 (to get in to service mode press in sequence clear modes 1 0 7 and hold red stop for 5 or so sec. At the top of the screen should be direct SP highlight this and press the 59121 and it will take you right there.-Carl
Jun 28, 2009 | Savin 9935DP Laser Printer
Jun 28, 2009 | Ricoh Aficio 450 Copier
Jun 02, 2009 | Ricoh Aficio 450 Copier
55 people viewed this question
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
