Installedmemory now pavillion ze4610 just beeps and shuts down.
I am adding new memory to a very old laptop an HP Pavillion ze4610. I have 2 x 512 mb pc2700 memory. installed together or separately in either slot the cause the computer to beep on power up and then shut down. The machine works with the original 2 x 256 mb pc2700 memory.
  • 7,627 Answers
Make sure your battery is removed, unplug, reseat memory mods, make sure they are inserted fully. I assumed the 512MB are used? New? There is no reason , that I can come up with, they should not work? I have upgraded many memory mods without incident.
Posted on Dec 03, 2012
oldnovii
  • 667 Answers
SOURCE: HP PAVILLION dv 9000 laptop new bios instalation instructions
Would you mind just adding a comment to this post. Please just copy the text body part of the email and paste in a comment. No need for your name or email addy or personal info. Also please tell me which operating system you are using. Thanks.
Posted on Mar 28, 2008
MUKHTAR
  • 2022 Answers
SOURCE: Pavillion DV1000 will not boot
just make sure the power cord is connected properly and u getting power on adoptor. still u r not getting the power then remove the battery and just on power some time it is happen bcoz of battery fault
Posted on Jun 11, 2008
  • 398 Answers
SOURCE: HP pavillion DV6000's battery charger beep sound
try buying a new battery
Posted on Mar 07, 2009
SOURCE: one long beep, two shorter beeps - HP laptop will not start up
Hi...
I had the same problem...
The solution is only temporary and you will have to reapply it after around 5 to 6 boots cuz it'll just happen again (the beep syndrome).
Just heat up the laptop by turning it on and covering its air vents with your hands.
Then after you hear the beeps turn it off.
Turn the laptop on again and immediately turn it over upside down with the lid closed ofcoarse (simply put it on its back).Hopefully you wont hear the beeps and when you open up the laptop lcd...voila display.
Posted on Apr 13, 2009
  • 8 Answers
SOURCE: hp pavillion dv9500 not turning on
It is a design/manufacturing flaw in the nvidia gpu due to overheating. some consumers are attempting a class action suit
Posted on May 28, 2009
Specs
There are 2 memory slots; one is under the keyboard, and the other is accessible through the center plate on the bottom of the laptop. Here are links to the replacement diagrams and HP replacement part numbers. You can have a maximum of 2GB memory in the laptop.
Upper memory replacement
Lower Memory Repolacement
1024-MB 350238-001
512-MB 350237-001
256-MB 370556-001
All are 333MHz, 200-pin, PC2700 Small Outline Dual In-Line Memory Module (SODIMM)
Feb 28, 2012 | HP Computers & Internet
When i power up my hp pavillion laptop the screen stays black and it beeps 3 times and does nothing
3 beeps is usually related to the memory.
Try re-seating / booting with just one stick of memory and see what happens.
Oct 09, 2010 | HP Pavilion dv9000z Notebook
I have a Sony Vaio FX802 with 384 MB ram, split 1 x 256MB and 1 x 128MB across 2 banks. Last week I noticed that I was running on 256MB only so I re-seated the 128MB module and that seemed ok for a time,...
when adding new memory always take all memory out, reinsert the new 256mb stick into the first memory socket dimm1 normally, boot the laptop up, if the laptop boots then fine the memory module is ok, shut down and insert the original 256mb into the second slot, dimm2 then boot the laptop it should now boot normally, if not there maybe problems with the memory slot itself, give it blow to get rid of any dust and try again, if this dosent work post back.
Aug 20, 2010 | Sony VAIO FX150K Notebook
I have a HP Pavillion 2005. it would shut down
Could be your fan is bust or very dirty try cleaning it and the air vents. NB opening your pc may void warranty.
Mar 30, 2010 | HP Pavilion zv6203cl Notebook
I just got a 1 gb ram memory from you for my pavillion zv6000 laptop. I opened the back to install it and there is a ram in there already. I thought I was just adding memory. help
http://h10032.www1.hp.com/ctg/Manual/c01035677.pdf
section 5.6 gives memory specs, earlier in the manual it only refers to one memory slot. You have to pull the existing one.
I always tell my customers what the max memory you can install, and what will have to be removed. Apparently someone else didn't.
You might want to download that pdf. It's the full maintenance manual on your machine.
Jan 08, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Whether DDR is compatible for hp pavilion dv1000 or only sdram is compatible. With which ram can i upgrade.
According to the maintenance manual only 266Mhz Ram can be added to the notebook.
This would be SDRAM.
Hope this helps!!
Kind regards!!!
Jan 06, 2010 | HP Pavilion dv1000 Notebook
Hi, the problem is that when the HP Pavillion is switched on thereis a very loud beeping sound. One long and two short beep together. It renders the unit useless because it does not switch on for sometimes...
i think its an motherboard releted problem the beep sounds you told hear is produced by motherboard when it is facing any complaints in side it ask a certified HP technichian
Oct 19, 2009 | HP Pavilion dv9000z Notebook
Adding RAM causes PXE-e61
Most likely you have a slow or dieing hard drive that is why when as you state you add correct ram upgrade the unit fails to boot.
skip the ram and replace your hard drive with a new ssd (solid state drive)
https://forums.lenovo.com/t5/Lenovo-P-Y-and-Z-series/PXE-E61-Media-Test-Failure-check-cable-Ideapad-z580/td-p/1318353
Feb 16, 2018 | HP Compaq Presario V2403NR Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
