Question about Dell Studio Computers & Internet
My dell sudio won't turn on I have replaced the motherboard and power supply any other ideas
    Novelist:
    Champion:
  • 233 Answers
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Posted on Dec 04, 2012
5 Suggested Answers
  • 132 Answers
SOURCE: A power spike broke Dell Precision M20 motherboard
Hi there!
Yes it really does damage the motherboard when that kind of things happen.
You'd rather replace the motherboard than repairing it.
Hope this helps!
Posted on Mar 20, 2010
rockitman187
  • 2559 Answers
SOURCE: I have a toshiba satellite
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Posted on Jun 29, 2011
swapnesh_pan
  • 7 Answers
SOURCE: dv7 motherboard won't turn on
used good power jack and check for wrong soldering&tracks cat
then joint the power jack its work
Posted on Feb 09, 2012
herwinpradan
  • 177 Answers
SOURCE: COMPAQ V2030US POWER ON WON'T START
if there are no Power light,you battery might be broken or your power button is broken,i suggest you to charge your battery or take it to notebook center (if charging still failed,it might be the button)
Posted on Aug 28, 2012
COMPUTER WON'T START
See if power supply fan is running. If not....the power supply is bad. Also...see if there are any lights lit on the Motherboard. If not....the power supply is bad. You can pick one up on ebay pretty reasonable. Hope this helps.
Feb 02, 2013 | Dell Inspiron Computers & Internet
P8P67 EVO Won't Boot with power to board
This is almost always the power supply. How exactly did you "check the power supply"? You checked all 12 or so voltage outs under load?
If replacing the power supply doesn't work, replace the motherboard.
Dec 24, 2012 | ASUS P8P67 EVO LGA 1155 Intel P67 SATA...
Computer shouts down in 15 to 20 seconds after starting
The specs say the PSU is ATX compatible. Whether that is for the connector only or for the whole power supply is something you will have to determine.
If you have an ATX power supply handy (like in an old computer) give it a try. This one is only 300 Watts so it won't likely be expensive to replace.
Have a look at: http://www.techspot.com/community/topics/dell-dimension-1100-shuts-down-after-20-seconds.135987/
Aug 28, 2012 | Dell POWER SUPPLY Power Supply
Amber light is flashing on my computer and it won't turn on at all. Help!
The Dell Dimension 300 gets the amber blinking light when there is power to the computer (the power supply) but the motherboard isn't getting the correct power. Sometimes it can indicate a motherboard fault or that the power supply is not set to the correct incoming voltage.
Check the back of the computer. If the power supply has a switch for incoming voltage, make sure that it matches your incoming voltage. Next check that the main power cable (20 or 24 pins depending on the computer) is fully seated on the motherboard. (It can only be connected one way and should lock onto the connector on the motherboard.)
Next check that the power supply is providing the correct power. You can simply install another power supply (known to work on another computer). Make sure that the PSU is correctly sized for the computer components. Alternatively use a multimeter or a dedicated power supply tester or put it in a different machine.
If the problem is not cured with a new PSU, the motherboard has a failure. Unfortunately, it's difficult to identify the exact bad component. (If a major component other than the CPU on the motherboard had failed, the diagnostic lights or beep codes could help identify the issue.)
I hope this helps.
Jun 10, 2012 | Dell Dimension 3000 PC Desktop
Yellow light blinking on my Dell Inspiron one 19 and won't start up
if you have replaced the MB and power supply, then the from IO panel could be the failed component
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
My computer suddenly lost power and now it won't even turn on.
replace the power supply of your cpu check if the blower fan is spinning during power on it means that your power supply is good if not replace the power supply with a new one
Sep 12, 2011 | Dell Inspiron 537 MT Desktop Computer
I have a Dell Precision M60 laptop and the charger adapter's led light is on when i plug it in, but the laptop won't turn on.I've replaced the battery and tried a different charger but that...
Unfortunately it sounds like you have an issue with your motherboard. If you remove the battery and just try to power on the laptop using the AC adapter and it still won't power on then it's probably the motherboard. The power supply circuit (where the AC adapter plugs into) for the motherboard is integrated into the motherboard.
Sorry. If it's still under warranty Dell will replace the motherboard.
Sep 10, 2011 | Dell Precision M60 Notebook
I accidently plugged in my Dell Inspiron 518 into a 220 v outlet without switching over the red tab on the power supply. I heard a loud boom and smelled smoke. I've since replaced the power supply,...
I really hate to be the bearer of bad news, but your motherboard may have been fried. The power surge was probably too much for it to handle, especially considering this isn't a custom build, so the parts inside of it are cheaper. Contact Dell Support and see if there is anything that they can do for you.
Aug 21, 2011 | Dell Inspiron 518 Desktop Computer
Dear sir! my dell optiplex gx 150 won't start when i press the power button but power supply will be start and pc can't give any beep ?
try to remove the power cable on that product and then hold the power button for 8 secs. Reinsert back the power cable and press the power button. If it won't turn on, then the power supply is the main cause of trouble. Contact dell right away for repair...
Jun 22, 2011 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
47 people viewed this question
Alun Cox
