Question about Moen HC400512 12" Hot/Cold Outdoor Sill Faucet...
Adjust sill faucet temperature - Moen HC400512 12" Hot/Cold Outdoor Sill Faucet...
2 Suggested Answers
  • 652 Answers
SOURCE: how to replace a cold only outdoor sill faucet
You will have to go below on the inside of the house rather it be a crawl space or a basement and cut the copper pipe and then splice the pipe with new line, All of the parts would be at local Home Depo store.
Posted on Apr 01, 2010
I have a Glacier Bay shower faucet that is getting increasingly harder to control water temperature out of shower faucet! Water temperature is very hot
check the hot water supply first and if needed adjust if to high and or check your anti scald setting --need to remove the center handle on the mixing valve
How To Adjust Glacier Bay Anti Scald Device Yahoo Video Search Results
Jul 31, 2017 | Glacier Bay Home
Tip
Adjusting the temperature setting on a Delta single handle faucet 13/14 series.
Delta single handle Tub & Shower faucet temperature control adjustment.
Step 1 - Remove handle to gain access to rotational limit stop. Once handle is off there ia a plastic limit stop disc. Remember where it is to start with. Metal handles require a 1/8" allen wrench to remove handle. Plastic handles require removal of cap to access screw to remove with phillip's head screw driver.
Step-2- To adjust the temperature of the water coming out of the valve, pull the disc back to a position where it is possible to remove the Rotational Limit Stop and readjust the teeth to desired position to acheive temperature. Once moved reinsert it into place to test water
Step-3- Clock wise will decrease the temperature and counter clockwise will increase the outlet temperature to a hotter setting. Temperature setting per tooth (notch) could result in 4 to 16 degree's based on inlet water conditions.
Check water temperatures to make sure it is at a safe temperature to avoid scalding. Safe operating temperatures range around 120 degree's. Some may have to be adjusted based on season's.
Winter season's when it is cold outside you may have to turn temperature up due to water coming into house will be colder than it would be in the summer.
on Jun 23, 2010 | Plumbing
How to turn up the temp. on a Rheem mod. 82v52-2 hot water heater
To adjust the thermostat, turn off the water heater. Then remove the access panel(s) and any insulation. The access panels are above the drain valve. Take a small flat blade screwdriver and rotate thermostat dial pointer. (The lower temperature settings are to the right.) Replace the access panel(s) and insulation and then turn on the water heater. Do not remove the protective cover on the thermostat.
Wait for water to heat and then check the temperature at various faucets. Make sure to adjust the anti-scald temperature limiter at any faucet that may be accessed by a small child or adult who might be injured by high water temperatures. (Just put a thermometer in the flowing water. Check the faucet installation information. The high temperature limiter will be under/behind the handle for single handle fixtures.)
I hope this helps.
Feb 21, 2015 | Rheem Water Heaters
The plumber reversed our hot and cold water supply for our Delta 1400 shower. This repair is not the same for the temperature adjustment is it? I have the handle apart and can see the adjustment but have...
I dont know if you really want to hear this but the faucet will have to be replumbed. The way this works is on the faucet you have 2 inputs (hot and cold) if they are not in there proper feed ports they will have to be removed and installed correctly. if they are installed using flex lines you can probably do it yourself but if its hard plumed (copper pipe) it will be more difficult as the pipes will have to be cut and moved.
Jun 22, 2011 | Delta & Single Handle Shower Faucet
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
Have the moen 82300 2300 series positemp tub and shower faucet. can i make this a nonpositemp by replacing the cartridge? We are unable to regulate cold or hot temp. no matter where the handle is the...
Temperature regulating faucet, aka anti-scald, are fast becomring a requirement under local building codes making it, technically speaking, a building code violation to alter the faucets function (assuming someone reported it the loccal buildings dept. That said the function of the anti-scald faucet cannot be altered. You should contact whomever installed the faucet to come back and adjust it so the temperature is more suited to your needs.
Jun 20, 2010 | Moen & One Handle Tub & Shower Faucet
How to replace a cold only outdoor sill faucet
Mar 31, 2010 | Moen Plumbing
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
Temperature problem
there is no adjustment.. if it worked well in the past you need to replace the cartridge as that controls everything.
Mar 07, 2009 | Kohler Plumbing
Moen HC400512  12" Hot/Cold Outdoor Sill Faucet... Logo
43 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
