Question about Graco Alano Travel System Emelia 7F07EMA3 Stroller
Lockable front swivel wheels with suspension
Modelo 7111BKWJJ
Is it possible to buy or adapt the rough terrain wheel for the bugaboo cameleon to swivel?
all bugaboo strollers came with swivel front wheels . There is a white sliding button on the front of the swivel assembly that locks the swivel action. The swivel castors are only on the front but can be assembled incorrectly on the rear of the stroller
go to google and type in base.bugaboo.com and there is a pdf manual for the strollers.including how to assemble and the wheels and castors.
Feb 10, 2015 | Bugaboo Baby Gear
I have a 1996 Ford Windstar my problem is the front end makes a tumping noise
Check out the Upper Suspension Turrets of the Struts, and/or, the Lower Suspension Arm anchor bushes/Lower suspension Swivel ball joints. The tightness of the nuts on the Steering Box mounting on the Cross member.
Regards,DT
Apr 26, 2011 | 1998 Ford Windstar
On the rear suspension on a Pontiac Grand Am SE, there are 2 rods that come from the middle of the trunk over to the tire and one from the front of the wheel area back to the wheel. What are those rods...
not sure what you are trying to look for, but this site "http://www.partsgeek.com/ymm/2001/pontiac/grand_am.html" has some good pictures that may help.
Apr 17, 2011 | 2001 Pontiac Grand Am SE
Does the steering wheel control the wheels? Are the front wheels supposed swivel or stay in one direction?
theres no problem no the wheels arnt turned with steering wheel and the front wheels are supposed to swivel hope this helps if yes please giv thumbs up thanks
Mar 06, 2011 | Little Tikes Cozy Coupe
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
Quinny buzz front wheel just swivels.
Hi you can buy new & used very cheaply on ebay
Mar 11, 2010 | Quinny Buzz JUICE 2007 complete Brand...
The front wheel wobbles when it's on swivel, what
The wobbling front wheel problem is easily solved. Simply remove the two philips screws from the plastic cap covering the from wheel assembly on the foot plate. (Where the break cable goes into the swivel tube) Now tighten up the large black nut with a spanner, replace the black cap and your done!
Mar 06, 2010 | Jane Baby Gear
The front wheels on my Maclaren XLR keep locking up
When you click the wheel release (to make them go onto swivel mode) press a little harder as it sounds like you haven't fully engaged the release mechanism.
I hope this helps.
Oct 07, 2009 | Maclaren Vogue Umbrella Stroller
Baby trend expedition double jogging stroller
No but if you just sort of push on one side of the handle bar it will pull it to turn without lifting the front.
Aug 25, 2008 | Baby Trend Expedition Double Jogger
How can I fix the alignment of the wheels of a Bugaboo Cameleon stroller (it veers to the right)?
There are two answers to this problem:
1) The suspension on the front swivel wheels on the Cameleon are adjustable. As the child gets older (and heavier), his/her weight might effect the handling of the stroller. It is recommended that the suspension be adjusted. To do this, move the suspension adjustment forward, as it increases its strength.
2) There has been significant conversation about this problem with the Cameleon's veering if the chassis was purchased before 2007. If so, contact bugaboo via bugaboo.com. Bugaboo will ask you for your serial number, etc. to research whether it is something that is obviously defective.
If you have any further questions, or need help contacting the company, don't hesitate to contact us anytime!
strollerinfo@gmail.com
StrollerInfo
Aug 25, 2008 | Bugaboo Cameleon Jogger
Graco Alano Travel System Emelia 7F07EMA3 Stroller Logo
15 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
