Question about Hasselblad Photography
Hi, i have a hasselblad 500cm and is giving me tne negatives wich are too close to each other or iiregular space; thanks
  • 685 Answers
Send to a repair facility like CRIS or United camera repair. This is something mechanical that cannot be repaired at home.
Posted on Dec 15, 2012
  • beto bermudez Dec 18, 2012
    yes, ok, thank you
2 Suggested Answers
Obertelli
  • 3006 Answers
SOURCE: Hasselblad 500CM. Film is blank when
The only possibilities are that the shutter is not working when the lens is mounted on the body, that the film is being inserted incorrectly with the backing paper facing forwards, or the film processing is completely wrong.
I haven't suggested that the film isn't winding through the camera as I'm assuming that when you remove it the film has all transferred to the previously empty spool. I've also assumed that when you describe the processed film as "blank" that you mean it is completely unexposed (clear) as opposed to completely exposed and washed out (opaque).
Posted on Jul 10, 2009
500cm jamed
Depending on the age of the camera, I gather that the screw we are turning is the one that sets the lens spring? IF so you must turn it almost one whole turn and the more you turn it the harder it gets to turn! It will latch when it gets to the right spot and then you can take the lens off! Be very careful! if you slip off the screw with the tool, you can damage the lens.
Jun 10, 2017 | Hasselblad Photography
Hi i need to no wich color wire is posative an wich is negative on a samsung charger model/tad137use 1 wire is white an 1 is bare but wich is wich pleas help me
With your issue, White cable is usually the Negative polarity. If it is already the output of your mobile charger. If White is not the Negative try the other one. Don't worry, it will not damage your battery or that charger itself. You can tell if it is not working. If that happens, try switching the cable. I tried it. believe me.
Cheers!
May 31, 2011 | Cell Phones
Im changing a pressure switch for some one.they took the old one off and doesnt remember wich one was possitive and negative.I figured the positive and negative out on the spa.How do i know with one to...
It does not matter the switch just opens and closes so the two wires can go on either terminal and it will work just fine...
heatman101
Sep 18, 2010 | Pool & Spa
Hasselblad 500cm body frozen/jammed
Check the release button lock tab, it may be engaged, holding the release button in
Aug 17, 2009 | Hasselblad 503CX Medium Format Camera
Hasselblad 500CM. Film is blank when developped.Shutters seem to work and slide is removed before shooting.
Jul 09, 2009 | Photography
1,2,4 hasselblad cft* 80mm speeds runs like 1/30
Those speeds tend to hang up from lack of use. You can try exercising them by cycling through the speeds, but it will most likely need service. The lubrication on the gear train has probably dried up, it is a common problem since those speeds aren't normally used.
Sep 28, 2008 | Hasselblad Cameras
Which Hasselblad?
There were several versions of the 500C/M as production was over many years. The 501C had all the latest revisions of the 500 C/M series to make it the better choice. You'll get more $ for the 501 for this reason. Later versions of the 500C/M had a much better coil spring to control the mirror for starters. Unless you are going to use this camera for daily professional use, either would be a reliable camera. A good way to check the amount of use on any Hasselblad is to look at the back of the camera where the film magazine mounts. A good solid black with no shiny spots on the plate would indicate little use. There are raised lines around the aux. shutter opening that will wear as film back are removed and replaced.
Nov 12, 2007 | Hasselblad 203FE Medium Format Camera
Photography Logo
209 people viewed this question
Top Hasselblad Photography Experts
Tony
Are you a Hasselblad Photography Expert? Answer questions, earn points and help others
