Question about Fujimi 1/24 Fiat 500 Abarth
Media button says "no source available."
Ipod is plugged in, and when the media button is pressed I am told "no source available." My wife and I have tried all sorts of ways to find a solution from unplugging and plugging back in to restarting the ipod. Fuses are fine. Loose wiring maybe?
Tip
How to make the sound of the iPod Better
<p>Take your music with you on your iPod, portable media player from Apple. Depending on iPod model can hold between 500 to 40,000 songs. No matter how small or large your music collection, not content with mediocre sound quality while enjoying your music. Using a combination of hardware and software settings of the iPod add-ons to your iPod pump up the jam like never before. <br /> <p><br /> <p>1. Change the iPod music equalizer. These changes and increases the sound from the iPod to better match a specific style or genre of music. Press "Menu" on the front of Click Wheel iPod. Go to "Settings" and press the middle mouse wheel. Scroll down and select "EQ". Select the type of music you listen to (e.g. "Rock") and press the middle button of the Click Wheel. <br /> <p><br /> <p>2. Sound set control function for all your iPod music playing in the same volume as surprising increase or decrease in volume between songs. Click "Settings" from the main iPod menu and choose "Sound Check" to turn it off. <br /> <p><br /> <p>3. Use headphones instead of earphones that came with your iPod. While the earbuds feature enough for everyday use, audiophiles cannot enjoy the limited range of buttons compared with headphones bigger and more powerful. Additional benefits in some models of headphones, such as blocking noise canceling ambient noise, also can help improve your iPod listening experience. <br /> <p><br /> <p>4. Connect the iPod to a stereo amplifier or iPod compatible. This adds low-range and headsets that many cannot create and is ideal for cases where you connect your iPod to share with a group sounds like a party. <br />
on Aug 09, 2011 | Apple iPod touch
Ipod classic 7th generation won't sync
Step 1:
With iTunes software, iPod users can manage their media libraries, purchase or import new content and synchronize their devices. The software has a number of convenient features, one of which is AutoSync. This feature will cause your iPod to automatically synchronize with iTunes immediately upon connecting the device to your computer. You can also set up iTunes so that you can manually sync your iPod.
Press the "Shift" and "Ctrl" keys on your computer keyboard simultaneously while you connect your iPod to the computer using its USB cord. Mac users will press "CMD + Option" while you connect. Continue to keep the keys pressed down while you monitor the iTunes window. Keep the keys pressed until you notice that Auto-Sync has stopped and your iPod icon has appeared in the Source pane of iTunes. Be patient, as this could take between 5 and 30 seconds. Right-click on the icon for your iPod in the Source pane, and then select "iPod Options." Click to put a check mark in the "Manually manage songs and playlists" check box. This finishes your task and you can now manually synchronize your iPod whenever you wish by simply clicking on the "Sync" button.
http://chris.pirillo.com/ipod-tips-and-tricks/
Feb 10, 2013 | Apple iPod classic 7th Generation
Tip
How do I get Bluetooth on an iPod
<p>The iPod touch version of the personal media player includes a Bluetooth antenna for wireless connection with other devices to determine. Using the wireless settings of the software on your iPod device with Bluetooth capabilities, allowing the player to other devices in his pocket area. Enabling Bluetooth takes only a second or two, and the iPod will immediately start looking for other Bluetooth devices. <br /> <p><br /> <p>1. Touch the "Settings" icon on the home page of the iPod screen, and press the "General". <br /> <p><br /> <p>2. Press the "Bluetooth" in the sub-menu. <br /> <p><br /> <p>3. Push the "Bluetooth" refers to the "ON" position to.. <br />
Tip
The battery of my iPod is not charging
<p>When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly. <br /> <p><br /> <p>1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod. <br /> <p><br /> <p>2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod. <br /> <p><br /> <p>3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer. <br /> <p><br /> <p>4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen. <br /> <p><br /> <p>5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal. <br />
"frozen/ hung" how can i reboot my ipod or
Try this method:
- Press and hold the Home button and the Power button together for about 10 -15 seconds. This should shut down your ipod. If you pressed it too long or pressed home too long, it will go into recovery mode. In which case, you ned to press the home and power button together again.
If your ipod is sync with your pc/mac, you can try plugging it in and your pc/mac should detect it and show you options like restore or something.
hope this helps.
May 04, 2011 | Apple iPod nano 3rd Generation
Tip
How to make a Wi-Fi for your iPod?
<p>The iPod Touch has Wi-Fi capabilities so you can connect to wireless networks within range of the signal from your iPod. Understanding of how Wi-Fi connectivity and login to activate an available wireless network is essential to ensure proper network activity on your iPod touch. Get the most from your iPod to access the network for updates, instant messages and downloads. <br /> <p><br /> <p>1. Click the "Settings" button on the touch screen in front. <br /> <p><br /> <p>2. Touch "Wi-Fi" and press "On" to activate the wireless network. <br /> <p><br /> <p>3. Tap "WiFi" and wait for the list of networks available to fill. Tap the name of the network to connect. Tap "Join" when the iPod does not connect automatically. <br /> <p><br /> <p>4. Enter the wireless network password or encryption key as requested. The network administrator's password if necessary. Hit "Connect". <br />
on Aug 05, 2011 | Apple iPod touch
Tip
The iTunes software update for iPod Touch
<p>ITunes is a media management program launched by Apple built to help manage content for all Apple iPod, personal media players, including iPod touch. You can use iTunes to load and delete songs, apps, podcasts and a variety of content on your device and back up your iPod touch. Before installing the software update on your iPod touch, you should update your iTunes software. Typically, iTunes prompts you to update the program when there are updates available, you can also manually check for updates in iTunes. <br /> <p><br /> <p>1. Launch iTunes. <br /> <p><br /> <p>2. Click "Help" from the toolbar menu at the top of the program window and click "Check for Updates". The program will prompt you with a new update, if available. <br /> <p><br /> <p>3. Click the "Download iTunes". Apple Launches Software Updater. <br /> <p><br /> <p>4. Click the box to the left of the "iTunes" and click "Install an item" button. <br /> <p><br /> <p>5. Click "OK" to confirm the terms of use agreement. <br /> <p><br /> <p>6. Apple Software Updater will automatically download and install the update from iTunes. The updater closes iTunes prompts you to restart your computer to complete the upgrade. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How do I add music from your iPod to a new computer?
<p>The media player will not allow iTunes users to transfer files from one device to the iPod library. ITunes only allows one library to the device. This route is a unidirectional transfer problem for iPod users who want their music to be added to other computers. You can transfer music from your iPod to a new computer, but discovering the hidden folders on the device. They contain information about your iPod music files, which can then be copied to the PC. It takes only minutes to discover the hidden folders and transfer music to start. <br /> <p><br /> <p>1. Locate the USB cable that came with your iPod device. Plug the cable into the groove bottom of your iPod. Connect the other end of the cable to an available USB port on your computer. <br /> <p><br /> <p>2. Turn on the computer. Wait for the machine to boot. Click the "Start" button and then select Control Panel. Double click on the "Portable Media Devices" icon. <br /> <p><br /> <p>3. Double-click your iPod in the list of available units. Click the "Tools" menu and select "Options." Choose the option "Show hidden files and folders" option. <br /> <p><br /> <p>4. Open the folder called "\ iPod_Control \ Music". This folder contains all audio files on your iPod device. The tracks are divided into sub-folders by artist. Then click and drag the entire music folder to your desktop or drag the individual tracks of the sub-folders. Your computer will automatically copy the files to your hard drive. <br />
Tip
Ipod/ iphone software update
it couldn't be easier to update iTunes, just choose "Check for Updates" under the iTunes menu on a Mac, or from the iTunes Help menu on a PC. This checks both your iTunes software and your iPod software for updates. If both are up to date, you'll be told that iTunes is up to date, if updates for either are available you'll be offered the appropriate update. On a Mac you can even use "Software Update..." under the Apple Menu from your desktop.<br /> To check just for iPod software updates, connect your iPod to your computer, launch iTunes, and choose the iPod in the Source pane. From the iPod Settings Summary tab that appears, if the Update button is available-black, not grey-then new iPod software is available. Just click the Update button and follow the directions.<br />
on Mar 16, 2011 | Cell Phones
Fujimi 1/24 Fiat 500 Abarth Logo
41 people viewed this question
Top Fujimi Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Fujimi Toy Expert? Answer questions, earn points and help others
