Question about Verlinden Toys
Verlinden king tiger engine pack 2117
Assembly instructions that are more complete than those in the box.
2 Suggested Answers
  • 43113 Answers
SOURCE: Can i please get assembly instructions for the Akira king bed one page missing in the box cheers
Request from Akira.
Posted on Feb 03, 2018
I have been given a king parrot cot but without instructions or bolts. It has Boori on base. Can you help with this. Thanks
Hi. Sorry to hear of this problem you are facing. Please allow me to try to help you.
First, it might help you if you used the assembly instructions. By using these, you would thus be ensuring that everything is secure and in place. You might be able to download these instructions here...
https://www.flickr.com/groups/4124706@N24/discuss/72157688278090803/
You could also download instructions for your king parrot cot assembly over here...
https://s.productreview.com.au/products/manuals/26459_58c894895c2c9.pdf
Hope that helps.
Best wishes. Regards.
Nov 06, 2017 | Baby Gear
How can I get assembly instructions for a Main Stays Metr0 Desk Item 564063978?
Go back to Walmart and request them. Sometimes the instructions don't get packed in the box.
Mar 26, 2017 | Furniture
Did washington sstate senators vote in favor of un resulation 2117
Hi Wayne....The Senate voted 53-46 against the UN Resolution
2117.
Regards,
Dennis
Oct 11, 2014 | Televison & Video
K1500 1994 transmission wont shift
Not knowing your professional experience at rebuilding transmissions, I would say that with the installation of the kit there has been some errors made in the assembly of the system. Run the fault codes to see if there are wiring issues and TCM issues and have a pressure test done on the box to detect any problems with pressures and operations of the bands and clutch packs. I would leave the box in place until I found out exactly what is amiss or I would not know if it was fixed or not.
Dec 01, 2013 | Chevrolet Cars & Trucks
Tiger Jumbo remote on LG tv and Virgin media
Set-up instructions are so much to type in here, and is not possible too. If you wish to get more details, check the sites linked here. It has set-up code list and set-up procedure to most popular remote controls. http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide / Mosaic option.
Jul 13, 2013 | Brookstone 538744 Remote Control
How to install a blower moter and fan
Well, here's the instructions from the service manual. The labor guide says this can be done in 1.6 hours...I don't see how, unless the instructions are wrong about having to remove the instrument panel. My thoughts are that if you are only doing the blower motor, the blower assembly will come out without pulling the dash. You probably only have to do a partial disassembly and remove the glove box and the glove box lower support.
BLOWER ASSEMBLY
Removal and Installation
1. Disconnect battery ground cable. Remove Instrument panel. (See Instrument Panel Removal) Disconnect resistor connector. remove blower assembly duct. Disconnect motor connector. Remove blower assembly
2. Remove blower assembly screws and blower motor assembly. Remove clip and fan from assembly. Separate motor case and remove blower motor. To install, reverse removal procedure.
INSTRUMENT PANEL
Removal
1. Disable air bag system. See AIRBAG RESTRAINT SYSTEM article in ACCESSORIES/SAFETY EQUIPMENT SECTION. Disconnect negative battery cable. Scribe mating marks on steering wheel and shaft for installation reference. Using Steering Wheel Remover (J-29752) remove steering wheel. Remove steering cowl.
2. Remove instrument panel grilles and plug, or driving pattern indicator panel (A/T Models). Disconnect electrical connections. Remove instrument panel hood, instrument cluster ezel and instrument cluster. Remove hood release handle. Remove knee protector.
3. Remove dash fuse/relay block and side trim. Remove engine control module box. Remove radio console and glove box lower reinforcement. Remove speaker covers and glove box. Remove heater control panel knobs and cover. Disconnect heater control cables, and remove heater control panel. Remove illumination control knob. Remove instrument panel.
Installation
1. Install instrument panel. Install and adjust heater control cables. To complete installation, reverse removal procedure. Ensure mating marks on steering wheel and shaft align. Apply grease to contact ring and tighten steering wheel nut to 26 ft.lbs. (35 N.m).
Feb 28, 2011 | 1995 Isuzu Rodeo
How to replace headlamp bulbs on Triumph Tiger 955(2006)
Remove the screen 4 plastic bolts,
Remove the indicator mounts, 3 screws, 1 is to inside of the tank on either side of the headstock. you can let them dangle on the wiring if so desired.
Remove the bolts under the screen and the bolts under the indicator mounts , hex bits required.
Remove the fairing from the bike.
3 allan bolts, 1 ether side and one underneath support the headlight assembly. Once these are slackened you will have access to the rear of the lights.
Reassembly is the reverse, allow 45 mins to an hour to complete the job,
Apr 19, 2010 | 2004 Triumph Tiger
Can you direct me to instructions on how to change the oil on my 2002 road king?
need torque specs on head and gappingfor valves for a triumph tiger 650 1970s
Apr 07, 2009 | 2002 Harley Davidson FLHR - FLHRCI Road...
Toys Logo
Top Verlinden Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Verlinden Toy Expert? Answer questions, earn points and help others
