Question about Panasonic Lumix DMC-TZ3 Digital Camera
My Panasonic Lumix DMC ZR3 shutter won't open or extend the lens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
Posted on Dec 03, 2012
chironjilal
  • 40 Answers
SOURCE: How can I clean the INSIDE of a Panasonic Lumix DMC-LZ7 lens?
you can clean that with paint brush..
Posted on Feb 22, 2010
  • 11967 Answers
SOURCE: how to clean a panasonic lumix dmc ts1 lens
If the spots appear on flash pics only and are in different places on each photo, then the spots are not on your lens. Those are dust particles reflecting the light from your flash. It's a common problem with point-and-shoot cameras.
Posted on Mar 31, 2010
  • 1705 Answers
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
Posted on May 02, 2010
  • 11967 Answers
SOURCE: My panasonic lumix dmc-zs6 has
Try here: http://www.precisioncamera.com/panasonic-camera-repair.html
Posted on Jun 20, 2011
ZJLimited
  • 17970 Answers
SOURCE: Panasonic Lumix DMC-FH20 shows "SYSTEM ERROR
Sounds like the Focus and Optical Image Stabilization drive motors are bound or broken. To fix this wrong will need disasemble the lens unit, focousing unit to do service; if needs, replace the damaged parts and assemble to run normally. Don't do this if your camera is under warranty.
Or, unless there are no marks on the case and they wouldn't think that it had been dropped or gotten wet, well you know, Panasonic will normaly repair or replace it as long as it is due to manufacture defect.
Hope this helps.
Posted on Jun 22, 2011
Camera lens shutter does NOT OPEN!
Seriously this is not worth payi.g to fix unless you paid serious money for the camera. The shutter is also mechanixally tripped by the shutter button. Its a electrical charge that connects to the processing chip inside.
Jul 15, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
When I turn my Panasonic Lumix PMC-TZ3 on the lens does not open at all.... Please Help!!
Digital cameras have too many circuit connectors that could develop contact resistance without boundary lubricants. Cheaper to buy a new digital camera.
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
Dropped lumix but now everytime I switch it on its tells me to open the lens cover even when it is open.
It shows a problem with the motorized lens mechanism.I will prefer unscrewing the camera only if you are such an expert because there are very fine mechanics inside the Panasonic Lumix DMC-LZ2 which could be easily damaged if mishandled.Please take it to the nearest authorized service center.
I know this is not the solution you were expecting but I won't allow a much bigger damage due to mishandling.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 14, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
The lens on my panasonic lumix dmc-fx07k camera will not open or extend out. when you turn the camera on it sounds as if it is in the process of opening and coming out, but it does not.
Hi
Thanks for using FixYa. To start with try to blow compressed air around the lens cover so that if there is any dirt it cleans if off. You can also stick a thin strip of paper between the lens shutter and the outer support ring & move it in a way that it clears the debris that's stuck in there. If still the issue is not resolved then you'll have to replace the lens assembly & lens mechanism to fix this issue. It is recommended to be done by a professional. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Panasonic Lumix DMC-FX7 Digital Camera
Shutter is stuck. when I turn the camera on the
Have you tried to gently coax it open with something like a toothpick?
Jun 13, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
The camera itself.
shutter not openining. ccd flex not plugged in correct or it is faulty. main pcb fault. first turn the camera on then check if the shutter opens.
May 22, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
317 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
