Question about Microsoft Windows Vista Ultimate Edition
What's your problem?hi iam using winods vista ultimTE but i cant change the resolution of my screen
  • Microsoft Master
  • 27,725 Answers
Click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal
size, larger size or custom settings
Always click APPLY after making any changes
windows 7
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization.
Click Window Color and Appearance.
Under Window Color and Appearance, click the color you want, and then click OK.
Note
If you see the Appearance Settings dialog box instead of the Window Color and Appearance
window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero.
Hope this helps.
Posted on Dec 04, 2012
How to widen my screen
    • 1 Use the zoom in and out shortcut with your mouse. Many programs such as Internet Explorer, Firefox and Microsoft Word allow users to zoom in and out quickly using their mouse and keyboard. Hold down the "Control" ("Ctrl") key, and then move the mouse wheel forward to zoom in or backward to zoom out until the text fits your screen to your liking.
    • 2 Use the zoom command from your program's menus. If you don't have a mouse with a wheel or the mouse zoom shortcut does not work, try locating a "zoom" command in the "View" menu of your program. Many programs have an option to zoom in and out under the "View" menu, which will make text larger or smaller. You may have to select "Zoom in" or "Zoom out" several times before the text is the right size.
    • 3 Change your screen resolution. Altering your screen resolution can change the size of windows and text on your screen. Right click the desktop, select "Properties" (Windows XP) or "Personalize" (Windows Vista and 7), click the "Settings" tab (XP), or the "Display Settings" link (Vista) or click "Display" and then "Adjust Screen Resolution" (7). Adjust the resolution slider up or down, click "Apply" and then click "OK."
Oct 23, 2011 | Dell Dimension 2400 PC Desktop
My toshiba satellite pro is having a slight problem with the screen. the screen sometimes changes and its very rough and unnormal
If I'm understanding your issue, it sounds like your resolution is not set to your preferred resolution. If you're using Windows Vista/7, you can right-click on your desktop and click on Screen Resolution to change it to however you would like to see it. If you are using Windows XP, right-click on the desktop and click on Properties. In the Properties window, click on the Settings tab to change the resolution.
I hope this helps and thanks for using Fixya!
Sep 20, 2011 | Toshiba Satellite Pro L300 Notebook
Is the MSI 945GCM5-F 7.1 motherboard on-board graphic card compatible with LG Flatron wide screen? Up until now we had a GF card, but now it's gone, and using only the MSI we don't seem to be...
Hi
You don't say how big the screen is, what connectors it has [VGA (Analogue), DVI (Digital) or HD (High Definition)] or which Operating System you're using.
Right click on open space on your desktop.
Properties > Settings (XP)
or
Personalize > Settings (Vista, Win 7)
Left click & hold on the slider and slide to adjust resolution.
You are given the option to test and accept each setting change you make.
When satisfied, Apply > Yes > Ok. Then restart the computer.
If your screen is large and has Digital and/or HD capability and the above advice does not help you find a resolution setting thast completely satisfies you, you may need to consider a dedicated PCI-Express Graphics Card to upgrade your graphics performance and give you a wider range of resolution options.
Hope this helps.
Aug 23, 2011 | MSI 945GCM5 Motherboard
I need to adjuxt my screen size.
In Windows XP:
Start / Control panel / Display/ Adjust screen resolution and settings
In Vista:
Right click on desktop / Personalise /Display settings/ change display size and resolution
Not sure about Win 7 as I do not use it, but I'd think it similar to Vista
Jul 21, 2011 | Computers & Internet
After being on a few minutes, the text becomes very blurry I lowered the resolution, which makes the text bigger and helps some. There is an internal adjustment, but I don't know where??
Hi hamptonwhh,
Screen resolution refers to the clarity of the text and images on your screen. At higher resolutions, items appear sharper. They also appear smaller, so more items fit on the screen. At lower resolutions, fewer items fit on the screen, but they are larger and easier to see. At very low resolutions, however, images might have jagged edges. Please follow the steps below on how to adjust your screen resolution.
Windows XP
1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
2. On the Settings tab, under Screen resolution, drag the slider, and then click Apply.
3. When prompted to apply the settings, click OK. Your screen will turn black for a moment.
4. Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Windows Vista/7
1. Open Display Settings by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Notes : When you change the screen resolution, it affects all users who log on to the computer.
When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution.
Hope it helps.
Thank you for using FixYa.
Jul 04, 2011 | MPC Computers Envision EN 775e 17 in.CRT...
How do I find resolution settings on my Lap top which uses windows vista I need to change to 1024x600
To review and/or change your screen resolution settings, go to:
Start > Control Panel > Appearance & Personalization > Personalization > Display Settings > Resolution
If you change your settings, be sure to click on "Apply" when you are finished.
For step-by-step instructions, see this Windows Vista help page:
http://windows.microsoft.com/en-US/windows-vista/Change-screen-resolution
Mar 13, 2011 | Yahoo Mail
Attention autoconfig please wait -- this message keeps popping up in the monitor continuously. it also adjusts the contrast anf brightness some times automatically. please help
Sounds like the "auto config " is built in to your monitor. It selects screen sizing based on the resolution, sync timing, refresh rate, etc... that your video card is adjusting on the computer.
I would suggest you to try changing the resolution in Windows and see if still receive the alert.
For more information on Screen resolution and display on monitor, check the below Microsoft Help & How-To Articles:
1:
Change screen resolution :-
http://windows.microsoft.com/en-us/windows-vista/Change-screen-resolution
2: Getting the best display on your monitor :-
http://windows.microsoft.com/en-US/windows-vista/Getting-the-best-display-on-your-monitor
3: Troubleshoot monitor and video card problems :-
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-monitor-and-video-card-problems
If it is doing it often and you are not changing screen resolution I would say the monitor itself might have issues. It's possible your display driver may be corrupted. I would suggest you to download and install the latest drivers for the Monitor from the manufacturer's website.
For more information on Updating a Driver and fixing driver problems, check the below Microsoft Help & How-To Articles:
1: Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows-vista/Update-a-driver-for-hardware-that-isnt-working-properly
2: Tips for fixing common driver problems
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-driver-problems
Check the plug and cable, look for bent pins or pins pushed in.
Are you using one of those DVI/VGA adapters? If your monitor has dual inputs (DVI & VGA) have you tried using the other input?
Anyway you could check if the issue exists when the monitor is connected to another PC? Or maybe try another monitor on your PC?
source: answers.microsoft.com
Mar 12, 2011 | Computers & Internet
Sudden change to screen resolution on Spidaire Solitaire only
hi
sheiab try this
go to run and in run type msconfig and in msconfig try to change the boot oder of the computer and disable all start up from the computer and check the things would will definetly work
Jul 22, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
