Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
I own 2 model KUDS01FLSS1 KitchenAid Superba Dishwashers. The first unit had the clean light blinking so I read the post below and reset it. I thought everything was fine but half way during the cyc
I own 2 model KUDS01FLSS1 KitchenAid Superba Dishwashers. The first unit had the clean light blinking so I read the post below and reset it. I thought everything was fine after the reset seeing that the wash cycle started. The problem was about half way during the cycle it shuts down and the "Clean" light starts blinking again. Yes no clean dishes. This last time the water was actually hot or the rinse was but thinking it is not even allowing it to rinse since stuff is still not clean. After looking at the other problems and recommendations it looks like the heating element could be bad on this one. What type of diagnostic can I do hear to determine if it is the heating element or something else? Is the heating element pretty straightforward to fix? The other unit just won't start even though everything appears to be fine. It was working and decided to stop working. The lights are fine meaning the "Clean" light does not blink but even after reseting that unit there is no noise when the "normal" or start or combination of those too buttons are pushed. This one could be the door latch or maybe one of those cable things I read about in another post. Please advise what I should do with this one. My concern with sending a tech out I could run in to a thousand bucks in fixing the two when I should go out and buy something new that will be under warranty at least. Doubt I will purchase another KitchenAid based on review.s I have read lately
catriver
  • 878 Answers
SOURCE: Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Posted on Mar 08, 2007
bestdarngood
  • 3037 Answers
SOURCE: RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
The keypad interface is bad, you would need to replace that and then it should work great. Let me know if you run into any trouble or have further questions and I would be glad to help.
good luck
Posted on Jun 02, 2008
  • 25 Answers
SOURCE: KItchen Aid Dishwasher KUDI01FL Stopped Running and Will not Start
try the reset button sequence i posted in the other question..
Posted on Jan 24, 2009
SOURCE: Dishwasher Reset / Diagnostics
Unscrew and remove the kickplate at the very bottom of the dishwasher. The tech sheet with the diagnostic code should be attached to the back of it.  If not, due a websearch and you should be able to find the info on yahoo or google.
Posted on Jan 30, 2009
  • 423 Answers
SOURCE: Heating element circut malfunction In Dishwasher. Wash not workin
Great job walking through the possible causes! Hey, it is time to check the heating element itself. First visually, looking for brakes and then feeling for "bubbles" on the round element rod. Also see if it moves excessivly when you wiggle.
If no problem obvious, after you disconnect the dishwasher from power, use a multimeter to check for resistance (Ohms) If none, look for broken (heavy guage) wires and replace what's broken - probably the element itself.
If the element checks out good, suspect the thermistor then the controller/PCB.
Good Luck! Please report back what you find, OK?
Posted on Apr 11, 2009
How do I reset my Kitchenaid dishwasher that is blinking the clean light 4x
This post is saving me from buying a new dishwasher!! Thank you so much!! It hasn't worked in months
Apr 24, 2014 | KitchenAid Superba Architect II KUDE60FX...
How do I shut off the child proof lock on my kitchenaid superba dishwasher? There is a red light blinking and I have no idea how it came on as I did not push anything different than I usually do when I...
Hi
To reset the dishwasher control you have to press and hold the HEATED DRY button for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 16, 2011 | Dishwashers
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
"SANITIZED CLEAN" GREEN LIGHT IS BLINKING
This is an indication that the water did not heat properly, I have put some instructions together that will show you how to reset the control and what might have caused it. Follow the link below and let me know if it helps.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140, THE DISHWASHER IS NOT RESPONDING TO ANY COMMANDS, THE RINSE LIGHT IS BLINKING AND THAT...
I HAVE A DISHWASHER, KITCHENAID SUPERBA, I DON'T HAVE THE MODEL OR SERIAL NO#. THE ONLY NO#. I CAN FIND IS 8270140. The unit is not drying the dishes?
Oct 02, 2009 | KitchenAid Dishwashers
Red light blinking after replacing filter
Not positvie for that model but there should be a little reset button, or try just unplugging the unit and waiting 60 secs before plugging it back in. Hope that helps
Sep 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Jan 05, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
Kitchenaid dishwasher mdl: kud101t jbt0
try the reset button sequence.. described in that other post about the clean light blinking.. that will reset the whole machine..
tpug
Jul 07, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
297 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
