Question about NetGear WGR614 Wireless Router
How do i set up a network of 5 computers complete with a server and 4 workstations?
We have two laptops and 3 desktops, a router, cable modem and all the cables and wiring anyone would ever need for anything. What else do we need to set up an application server, workstations, connect to the internet, and have a storage system, including hardware, software, configuration settings. Step by step instructions and/or diagrams would be VERY MUCH appreciated.
  • 7,627 Answers
Perhaps this will get you started:http://compnetworking.about.com/cs/homenetworking/a/homenetguide.htm OR THIS :http://download.zonelabs.com/bin/media/pdf/homeNetwork_datasheet.pdf OR my personal favorite: http://www.dummies.com/how-to/content/a-typical-computer-networking-setup0.html
Posted on Dec 03, 2012
  • 8 Answers
SOURCE: Network Cable Unplugged
mairelina, if all was well 2 days ago then resetting the router should fix your problem. usually a small button on the back of the router.
chelliepooh, you need to check that the router's wireless function is on. connect using the ethernet and go to the config page (usually 192.168.1.1) make sure wireless is on and security is set to wpa-psk.
Posted on May 30, 2008
TBlessed 1
  • 61 Answers
SOURCE: Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Posted on Dec 01, 2008
redhaze89
  • 854 Answers
SOURCE: NetGear Wireless-G Router - Not detecting modem/internet
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 25, 2009
  • 75 Answers
SOURCE: I set up a home network some time back, but lately
I would not suggest to rurn off firewall. Instead would suggest to add exception.
Posted on Nov 09, 2009
Testimonial: "I agree. I am using a router, which acts as a firewall, but I still use Windows (YUK) firewall when possible. I am still having difficulty. Thanks."
  • 179 Answers
SOURCE: need a network password so i can get internt on my
Hi...
If you are trying to access the page 192.168.0.1 via wireless connection then I'm afraid it won't work.
You need to be connected to the router before you can access the routers set-up page.
You have 2 options.
1. Connect your macbook to the router with a ethernet cable then access page 192.168.0.1 or
2. On the back of the router is a small hole. (Reset Button) Using a needle or paper-clip press this button for about 10 seconds then release. This will reset the router to factory default settings and usually (Although not guaranteeing this as can be configured differently depending on where the router came from) mean that wireless is "OPEN" in other words no wep/wpa required.
Then you can access the page and set things up with passwords etc you can remember.
Also underneath the router should be the default wep key "IF" the wireless is passcode enabled.
And despite using 2 different netgear routers and updating the firmware. I have to now tell you.
They constantly locked up and dropped my broadband connection so bad I purchased different equipment.
Just FYI if you get connection issues.
Posted on Jul 17, 2010
How to change browser to allow conection to internet
To connect to the Internet you need a few extra things aswell as a network or wireless card and install the LAN or wireless driver.
1. You need to sign up with an Internet service provider.
2. Connect a LAN cable from your computer to the DSL or cable modem
3. You need a DSL or cable modem and connect and configure the modem to inaccordance with your Internet service provider's instructions.
4. Install Internet Explorer if it has not been done.
5. If everything has been done correctly, when you open Internet Explorer youcan access the Internet.If you have a wireless router and it is connected to the DSLor cable modem then -
To connect to yourwireless router, the router needs its wireless settings to be configuredwith the SSID, encryption key etc., also the wireless cards in all thelaptops/computers needs to be configured with these router's wireless settings.Then the laptops/desktop computers can communicate with your wireless router.
Dec 27, 2011 | Computers & Internet
I have an Internet Connectivity problem which I believe was caused by resetting our D-Link WBR-2310 router. We have a strange, perhaps illogical network setup in our office. Although it was set up before...
It appears you are not using the wireless connections on both the routers and the reason for using Router B was that there were insufficient LAN ports on Router A to connect to the two workstations that are connected to Router B.
To simplify your network, I suggest you replace Router B with a network hub or ethernet switch and connect the two workstations to this network hub/switch, then configure these two workstation to Obtain an IP address automatically. Router A will then issue IP address to these workstations via the network hub/switch.
Jul 09, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Jul 09, 2011 | Computers & Internet
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
I need to connect a D-Link router to my cable modem so that I can use my laptop anywhere in my home
Cable-modem <-- Ethernet cable --> WAN (or "Internet") port on the router
LAN port on router <-- Ethernet cable --> network-port on your laptop
Then, access the "built-in" web-server on the router,
and run the "Wireless Networking Setup" wizard:
* to set an SSID ("network-name")
* an encryption-level (Hint: choose 'wpa')
* a password for your wireless network
Then, disconnect the Ethernet cable from your computer,
and then "wireless available wireless networks".
Select your newly-created network, and connect to it.
Nov 14, 2010 | Computers & Internet
Problem 2Wire Router internet connection
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Nov 23, 2009 | 2wire HomePortal® 1800HW Router...
Had an extra router, brought it to my folks to hook up wireless for new laptop...connected through Comcast modem, all wired correctly...problem because laptop is an HP and modem is being run through Mac???...
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do: 1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok 2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer.. 3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank 4. it will show the setup page of the router. u can set the router on the specific internet setup that u have. a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet. b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security.. 5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe 6. If ur isp gives u a static ip address settings, u need to set the router to isp setup. a. how to check the isp of the isp given to u.. 1. click on start 2. run 3. type cmd 4. it will show a dos prompt 5. from the dos prompt type ipconfig/all 6. it will list the ip address, subnet, default gateway, dns server this settings should be type in to the settings on the router for static ip addressing.. 7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2. 8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access.. 9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon.. if you have any query pls feel free to get in touch.. good luck
Oct 05, 2009 | Linksys Wireless-G WRT54G Router
Can't connect to DHCP server
1. click on start
2. run
3. type cmd
Sep 28, 2009 | Buffalo Technology AirStation Nfiniti...
Internet no longer working, but internal network is fine.
i agree with all the above.. it's definately clear as mud how the network is designed and or funtioning. The machines connected to the wireless d-link router.. are they via cat5 inthe wired ports or wireless ? is the server the machine thats connecting to the switch and wiress router and modem? i'd say reset all switches modems routers and machines.. shut them all down.. then fire the cable modem, then the wireless router then the desktop switch then the server, the workstations and the one lonely wireless.. run "ipconfig /all" on all machines and if they aren't all sharing common ips and access, provide the results here for further investigation.
May 20, 2009 | Dell Dimension 2400 PC Desktop
Wanting wireless hookup
1)Prepare your modem. Unplug the modem's power cord and place the wireless router unit next to the modem. If the router has antennas, make sure they are raised to their full upright position.
2)Reassign your networking cable. Unplug the cable currently connected from your computer to your modem and plug it into the port located in the wireless router. This port is usually colored blue.
3)Connect the router and the modem. Use the networking cable that came with your wireless router to connect the modem and router unit. The router port is typically colored in green.
4)Start up your modem. Plug in the modem's power cord and wait 1-2 minutes while it configures its settings and prepares to connect to the Internet.5
5)Start up the wireless router. Plug the wireless router's power cord into an outlet and wait 1-2 minutes to get it started. The router is ready when the 'wired computers' and 'modem' icons light up. These logos or icons vary by make and model of your router so consult the owner's manual if needed.6
6)Insert your installation CD. Use the wizard or assistant to check the configurations of your computer settings and launch your wirelessnetwork clip_image001.gif
Things You’ll Need:
  • Wireless Router unit
  • Networking cable (comes with router unit)
  • Installation CD
  • Modem
  • Modem power cord
Dec 02, 2008 | D-Link DI 713p (DI-713P) Wireless Router
NetGear WGR614 Wireless Router Logo
24 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
