Question about General Electric WSXH208H Front Load Washer
Replace timer switch
How to remove timer switch
    Top Expert:
  • General Master
  • 9,472 Answers
Remove the top panel, then remove the console to access the timer.
Posted on Dec 04, 2012
How to remove a Intermatic 30 Minute Spring Wound Timer FF30MC
10-22-12
FF30 Intermatic timer: The turning knob pulls off.
(With some really old models, 1960s, there is a small set screw on the fat end of knob.)
Under the knob is a small hex nut that twists off to remove plate.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
http://waterheatertimer.org/How-to-wire-switches.html#gang
Oct 22, 2012 | Spring Step Intermatic 30 Minute Spring...
Installing a 7 day digital wall timer
Swylite LST100 timer has 4 wires. Red, Blue, Black, White
Timer has more wires than wall switch because timer has electric clock inside. And with + series Swylite timer, it also has led bulb that needs power.
Timer can replace ordinary on-off switch
-On-off switch has 2 screws, so 2 wires (plus ground wire) connect to on-off switch
-Three of the four timer wires are used when replacing on-off switch
-Red wire is not used, it is capped off
Timer can replace 3-way switch
-Three way switch has 3 screws, so 3 wires (plus ground wire) connect to 3-way switch
-One of the screws on 3-way switch is colored dark (it is crucial to identify the wire that comes off dark screw so timer can be wired correctly)
Lets replace on-off switch see diagram
Timer black goes to Hot wire
Timer blue goes to Load (light, fan, motor)
Timer white goes to Neutral
Timer red is capped off.
How to check which wire is Hot, Neutral and Load
Switch you are replacing has 2 wires > one is Hot, the other goes to Load
Remove these two wires. Separate wires so you can test. Turn on power. Tape tester leads to wood sticks so hands are away from power. Test each wire to bare copper wire.
When tester lights up >> that is Hot wire >> please connect this wire to Timer black wire
The other wire goes to Load >> please connect this wire to Timer blue wire.
Now test for Neutral. Test Hot wire to other wires inside box. Neutral should be white. When tester lights up, that is Neutral. Please connect Timer white wire to neutral. IF YOU DO NOT have a neutral, you can connect Timer white to bare ground wire until you have time to drop a Neutral into the box.
Replace a 3-way switch see diagram
Three-way switch has 3 wires.
Identify which wire connects to Dark screw on switch >> and then please connect this wire to Timer Black wire.
Timer white wire connects to Neutral
Timer blue and red wires connect to other two wires that came off switch ... they connect to either one.
Oct 01, 2010 | Solar Ivory Swylite Lst100+ Back-lit...
Cycle Buttons nor Start Button will not light nor work.
This may help you to pinpoint problem area.
Servicing Timer and Control Switches
Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
If your dishwasher won't fill with water properly or isn't drying the dishes, you most likely have a valve or heating element problem.
May 08, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I have an ariston lsi 45/50 which will not end it's wash cycle.i have checked the salt level,which is fine. Any ideas please?
HI Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.,,,,,,,,,,,,,,,PLEASE RATE IT..........THANK U
Nov 28, 2008 | Dishwashers
Electronic Timer sticks on Wash Cycle
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
Nov 10, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Dishwasher error code E4
Nov 06, 2008 | Candy Dishwashers
Teka Dishwasher DW6 59 FI Electronic. Stuck on rinse and will not operate on any programme
Oct 13, 2008 | Dishwashers
Kenmore 24 in. 17512 Built-in Dishwasher
Oct 12, 2008 | Kenmore 24 in. 17512 Built-in Dishwasher
Dishwasher not starting getting error of LH and LO depending on the wash cycle chosen.
Oct 12, 2008 | Maytag Dishwashers
Replacing timer switch
If you are replacing the timer, after you unplug it, first pop the plastic cap off the knob of the timer. Underneath you will find a small clip on the timer shaft that holds the knob on and makes it imposible to get the timer out without daming the know. Use a small flat head screwdriver to slide the clip to the side. Now you can remove the rest of the knob and the screws holding the timer in place. Next remove the screws along the top of the console. Push forward on the bottom of the console while gently pulling the top towards you. You will now see your timer laying there. Release the catch on the connector that holds all of the wirse to the timer. Reverse the process for instalation.
Jul 16, 2008 | Maytag MDE2600 Electric Dryer
General Electric WSXH208H Front Load Washer Logo
24 people viewed this question
Top General Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Chris Goulet
Are you a General Washing Machine Expert? Answer questions, earn points and help others
