Question about Briggs & Stratton Measuring Tools & Sensors
Problem with Briggs & Stratton 2400 PSI 190cc Gas Powered Pressur pressure washer, it locks up
  • 4 Answers
Try disconnecting the pressure hose and work backwards after that like remove the unloader valve and so on. Contact Flowjet cleaning equipment for help over the phone.
Posted on Jan 17, 2013
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
SOURCE: 123602-0131 BRIGGS & STRATTON ENGINE. NO LOW SPEED
Problem solved by replacing to two mentioned parts. I was told that sometimes it is also necessary to replace the camshaft as some of the plastic teeth on it could also be damaged.
Posted on Oct 11, 2009
  • 4088 Answers
SOURCE: gasoline leaking into air filter on Briggs &
The float/needle-valve/seat need to be looked at in the carburetor base. The float is not shutting off fuel flow when bowl is at design fuel level. Look for dirt/varnish or anything that interferes with float free movement or preventing the needle valve to close with the seat--usually, just cleaning these parts with spray carburetor cleaner and wiping with a clean cloth will restore operation. Try not to bend anything on the float assembly. Hope this helps!
Posted on Jun 07, 2010
  • 553 Answers
SOURCE: 18 hp briggs & stratton intek i can get it
Check the choke, if that doesn't work the old gas may have left residue that is plugging your ports.
Posted on Jun 08, 2010
SOURCE: I have a Briggs & stratton 18hp ohv riding
I also have this same engine and am also looking for the owners/workshop manual . Also went to Briggs & Stratton with no satisfaction. If you find anything please drop me an email aswell. Thank you. harmsen2@bigpond.com
Posted on Jul 18, 2010
How do i remove gas tank cover?
Hey Chuck
Not sure of the model washer you have but most Briggs tank covers only have 2 bolts on top holding the cover to the tank. If the isnt it can you be more specific with a model number?
Feb 20, 2015 | Craftsman 2700 PSI Briggs Stratton...
Will not start
is it electric or gas powered?
Dec 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
I cant start my power washer. the pull start is locked and wont release to start engine.
When the pull start gets locked, you have to release water pressure from the wand. I had the same problem last year.
Jun 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
I do like to know if this washer is good enough for my business as a used car dealer? Briggs & Stratton Murray 020456 2400 PSI 20 GPM 190cc Briggs Stratton
We power washed houses for years with a 2400psi machine. The machine weighed about 90 pounds. 1 strong man could pick up the weight, but usually it took 2 men to unload it from the trailer.
A small machine can advertise 2400 psi ... but that is for 3 square inches at a time. The heavier machine shoots a 10" or wider swath of 2400psi.
We ran our machine twice a week for years. We had a honda engine. I'm sure the briggs engine is good. I wouldn't buy a used machine... unless the price was low and it started on first pull. Electric starter on your power washer might be a repair-waiting-to-happen because it is constantly exposed to water and dirt.
Oct 19, 2010 | Briggs & Stratton Murray 020456 2400 PSI...
2200 psi husky briggs and stratton pressure washer used 2 years never used soap dispenser trying now is not drawing soap no longer have manual to see how to connect adjust can you help?
After a long none use, I tried to wash my driveway and powered on the washer,it did, but when i tried to engage the power washer by pressing the wand lever, it did not engage. What can I do to get the power washer working?
Jan 16, 2010 | Briggs & Stratton Gas Pressure Washer...
Measuring Tools & Sensors Logo
54 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
